hazel_trout changed their profile photo - Yesterday
ivan_anvil joined the community -
mossyelk joined the community -
briskshovel88 joined the community - Last week
charm.li free forever
89 olds swaybar
do you know were i can found the timing belt tensioner for this car the motor is 3.4 lq1 am changing the timing belt but mine is crying oil i need a new on the part number is GM 24503860 -
It's dusty........but not rusty. Nice climate in Peru.
