  1. Yesterday
  2. Last week
  3. Psych0matt
  4. Raffaelli
    Welcome.
  5. So my hunt begins for an intrigue with the 3.5, I'm looking specifically for a GL or GLS with the 3.29 gear ratio. Anyone know the RPO code for that to help me in my searches? Google and rpocode.com aren't helping me
  6. pwmin
    Welcome aboard!
  7. Hey everyone, My name’s Ryan, I’m from Long Island, NY, and I’m new to the Monte Carlo platform. I recently picked up a 2003 Monte Carlo SS and I’m excited to finally start a build thread and be part of the community. By trade I’m a licensed marine engineer, so I’m very hands-on mechanically and enjoy learning the technical side of things. On the automotive side, I’ve worked on and tuned a variety of platforms, everything from basic bolt-ons and wiring to full tuning using HP Tuners, Hondata, and standalone setups. I enjoy both the mechanical and tuning sides of builds and documenting the process. For the Monte, the plan is to start simple, catch up on maintenance, fix worn components, and do some basic bolt-ons while I sort out the body and cosmetics. Once the chassis and body are in better shape, the goal is to turn things up. I’m currently torn between a Gen V M90 top swap or going turbo, but either way the end goal is a "reliable", fun street car that still rips when you get into it. I’ll be sharing progress, asking questions, and learning as I go. Looking forward to seeing everyone’s builds and being part of the community.
  8. I am creating a database for GM Eaton superchargers and need the OEM part number for the SERIES I superchrger. Anyone? Anyone?
  9. Earlier
  10. 94 olds vert
    New member with 98 lumina
  11. rich_e777
  12. Luminator98
  13. rich_e777
  14. White93z34
  15. White93z34
    And a spam bot it was.
  16. Hi, I’ve just stumbled onto this forum, and i figure I’ll probably need to post here eventually acquired my luminator last year, 2nd owner from a grandma. 70000 (got w 55000)miles. Here’s some pics; thx yall
  17. 94 olds vert
  18. Does anyone have pictures of the factory door speakers in a 1992 (or similar) Cutlass Supreme coupe? I pulled a pair of door speakers from a 1996 coupe and I was wondering if the mounts will work. My 1992 currently has no door speakers. Thanks in advance!
  19. Here is info for the the swap based on my own experience of swapping my 88 cutlass w-body. 3800 swap w-body From 98/99 Monte Carlo z34/lumina LTZ with 3.8NA Needed - power steering lines (buy new) - Heater hoses (buy new) - Exhaust downpipe (or have one made) - AC system - all lines/parts from the engine bay (compressors can be from the gtp too) Best to have from the Monte Carlo/lumina but not mandatory - engine bay wiring harness - Cv shafts (buy new if you don’t have them) From gtp donor - motor - Trans - Trans cooler lines - rad hoses - Motor mounts - Cv shafts - PCM - Engine bay wiring harness Notes: cv shafts if using an HD trans you need to use the gtp passenger inner with the 1st Gen shaft and outer joint. If you get them from the Monte you can use the stock Monte drivers side. Wiring: if you can’t find the Monte Carlo harness you can use the gtp harnesss, and merge it into the 1st Gen c100 connector. With the Monte harness it comes with the c100 you just need to remove a few pins around and overall much easier but can be hard to find. You’ll need the GM service manuals for your donor harness and your original car to match the c100 connector. If using a Monte harness you will probably want to add the BBV wiring. This will also convert the car to obd2 PCM: you will need to get the vats/security removed(it’s possible it won’t be an issue but be aware it probably will be) and probably want to remove a few other codes. Rad: you could use your original, but the donor gtp rad will be bigger and fits into the chassis. I’d say it’s recommended but not 100% necessary.
  20. Black92GS
  21. rcLord510
  22. Hello everyone! I have a 2002 buick regal and it has the power drivers seat. Unfortunately one side does not move going forward or backward, and the rear up and down also doesn't work. The motors work fine as you can hear them when you press the buttons, however from what ive read on these they have plastic gears inside and they tend to break off. I saw a forum where someone said they had brass gears made and it worked, however he did not say where he sourced them from. My question is if anyone has repaired this before and if so did you get new gears or did you just swap out the motors? If so where did you source them from? Any info is greatly appreciated!
  23. RPE1992GPSE
  24. Very cool and very worth preserving and treating right. Its rare and in beautiful condition. Thank you for treating it right.
  25. What you see is actually *6PY* ....goes with *7PY* possibly front suspension FLH *6PY, FRH *7PY* 6PY 4 2 0 3 7 P FLH M COMPONENT FRT LH COMPUTER SEL SUSP (6PY) 8 9 0 2 0 1 E 1 E A 7PY 4 3 3 3 3 P FRH M COMPONENT FRT RH COMPUTER SEL SUSP (7PY) 8 9 0 2 0 1 E 1 E A
  26. Going by the RPO sticker, the fronts a little confusing. I’m assuming BPY code for the front springs
  27. This is pretty cool, I'll have to check which mine have later.
  28. amended
