Wow this thing is beautiful!!
GnatGoSplat started following Does anyone have any vacuum harness from any 2.8 V-6 or 3.1 V6?
Dorman does sell universal hard vacuum tubing. You can probably bend it to shape with a heat gun. Years ago, I just put heatshrink tubing over the cracks. Looked like an obvious fudge-fix, but worked fine. - Last week
90sEraWhips started following 3400
i have the rubber connector for the vaccum harness from my 89 2.8 v6 corsica, i’m looking for new hard lines for the vacuum harness now, one of mine has a hole, i can buy the lines if you still have them since you’re going with softer ones, maybe we can trade parts -
babyteef joined the community
torinstone joined the community
That's a daunting swap! Wish I had the balls to do it, but I draw the line at cutting away at a unibody frame that likely wouldn't have won any 1995 IIHS safety awards in the first place. You're all good BCM-wise, there isn't one. -
GnatGoSplat started following Radio replacement for a 1994 Cutlass Supreme Convertible and 1993 Cutlass convertible top not moving, down or up
Yep, I've probably removed the bezel a hundred times across 3 Cutlass Supremes and it's never broken. It's hard plastic and seems brittle, but it's actually quite durable. -
Ok, I take it by that wording the original rubber pads are not on the ends of the glas leaf, the glas leaf is riding directly on the nylon blocks. This is not an ideal arrangement, but other than getting a pair of the rubber pads in place there's little one can do, the ends of the glas leaf do not tilt upwards at all to allow the weight to spread out evenly at the very end of the leaf where the contact to the pad is, the very end of the leaf will dig into the nylon pad.
