96 wheel bearing/hub
Yes, pardon. So there was a base and SL level trim, or was anything above base a SL? Sorry for the added questions, just trying to learn more about the car. -
You mean SL? It's just a trim level. -
55.. and White..., Thanks for the speedy response and information! Still a bit curious, what is the LS option? - Today
Andrew T reacted to a post in a topic:
not even a difference ABS/non abs on the gen1 front knuckles. the sensor is separate of the wheel hub - why gm couldn't have continued this into the later cars is beyond me. buy whichever brand you determine to be the highest quality or fits within your budget -
55trucker started following 96 wheel bearing/hub
No difference to be had..... for the part # go to Rockauto.......search your vehicle, the hubs are a generalized item, there is no specific item for a premium vs basic car series, just ABS vs no ABS -
Andrew T started following 96 wheel bearing/hub
Looking to replace the the front (driver side I believe) wheel bearing/hub on my 1996 Cutlass 2 door base model. It appears there is a SL also but that the part is the same across the line. Can someone provide a part number and advise as to the SL difference, if any? Thanks
Welcome. -
Pollk joined the community -
Welcome aboard!
Viktor joined the community -
And a spam bot it was.
Kdog joined the community -
