  1. Last week
  2. Spoonnman
  3. Spoonnman
  4. White93z34
  5. Hey! Had my beautiful GTP for bit now and I am just wondering on the available for transmission rebuild kits for the MT. I know I remember seeing they were like basically impossible to get a long time ago but does anyone know of any that have been manufactured again? For the record it is the 3.4L DOHC V6 with a 5 speed, coupe, the only option it came in I believe. I would also like to learn some more about it if anyone has some random facts haha.
  6. Mach 5
    awesome!
  7. Bake82
  8. rich_e777
  9. Earlier
  10. SuperBuick
  11. 94 olds vert
    My Turbo 99 Z34 Monte Carlo
    Wow that car is awesome!
  12. White93z34
  13. Schurkey
  14. SuperBuick
  15. SuperBuick
  16. babyteef
  17. Ch3vyDude
  18. Ch3vyDude
    Wow this thing is beautiful!!
  19. Psych0matt
    TRW Keyless Entry module
  20. GnatGoSplat
  21. babyteef
  22. mdpierce8
  23. GnatGoSplat
  24. White93z34
  25. mdpierce8
  26. GnatGoSplat
  27. JulienStocola
