jiggity76 reacted to a post in a topic:
Holy Hell...how did I miss this!!!! This is pretty incredible and so glad I finally found this thread. I am here for any help. - Yesterday
Thanks. I should have worded that better. The 1227730 is not confirmed. I only listed it because I found TunerPro definitions that referenced the 1227727/1227730 family. I haven't physically verified the ECM service number yet. Before I pull the ECM, can someone confirm the factory ECM service number and MEM-CAL for a stock 1990 Cutlass Supreme 3.1 LH0 W-body? Also If the factory ECM is 1227727, which TunerPro ADX and XDF are you using for a stock 1990 LH0? - Last week
rjfranken joined the community - Earlier
