That video is one of those rabbit holes where you start with a tensioner and end up learning the whole LQ1 timing setup. Pretty handy to have around. - Today
hazel_trout changed their profile photo - Yesterday
ivan_anvil joined the community -
mossyelk joined the community -
briskshovel88 joined the community - Last week
charm.li free forever
wwindyibis joined the community -
fern_anchor joined the community -
89 olds swaybar
do you know were i can found the timing belt tensioner for this car the motor is 3.4 lq1 am changing the timing belt but mine is crying oil i need a new on the part number is GM 24503860 -
That's awesome, I often wish my Cutlass could end up somewhere exotic and I could live vicariously through it.
