1227727 and 1227730 use the same chips. One is waterproof and used in W bodies and Corvettes. 1990 is the only year to use $88 code mask. 88-89 are $6D. 91-92 is $A1. 93 is $DF. Thats for the 3.1 V6. The most common with all the data code layed out is $A1. I would use A1 to start and modify from there (because I have been tuning these for over 20 years and can do this). - Last week
55trucker started following 1990 Cutlass Supreme 3.1 LH0 (1227730 ECM) – Need correct TunerPro/WinALDL ADX/XDF and idle diagnostic advice
