do you know were i can found the timing belt tensioner for this car the motor is 3.4 lq1 am changing the timing belt but mine is crying oil i need a new on the part number is GM 24503860 - Last week
would any one know how to get a 3 port vacuum harness? ive got a 93 Buick regal with a 3.1 multiport Fi and i need a 3 port. i cant find any parts diagrams anywhere with a 3 port, and no junkyard within 30 miles of me even has an old 3100 engine that i can look at. ive found plenty of 3700 and 3800 of different makes and models, but none even have a 4 port harness. mine was badly rotted from never being touched for 30 years and ive lost powered brakes, my ac selector no longer works and my power steering locks up whenever i give it around half or more than a half press of my brake peddle, causing me to almost crash every time i have to make a turn without stopping fully. im going mad trying to search for it, every idiot behind a parts counter at every auto parts shop have no clue what im talking about and i can not for the life of me find a part number for a 3 port, i cant find any diagrams with a 3 port, and no one sells anything but a "do it yourself kit" with hose barbs and universal hose i have to cut to length -
55trucker started following 04 GP Shift indicator erratic!
99z34na joined the community -
primergray started following 1996 Buick Regal GS Coupe Survivor
96RegalGS joined the community -
Bigbloom420 joined the community -
Bigbloom420 replied to Drummer's topic in Powertrain
I just remove my rear heads. The exhaust we got with two open end wrenches from the top. I did spray some PB blaster but wasn’t 10 minutes after that. I can’t believe I didn’t hear about these hardly having heads blow. My Intake gasket is what it was I’m pretty sure but I guess I decided to go further. It’s a 2000 bonneville l36 series ii -
Stickman posted a topic in New Member Introductions
I have been passed down a 1992 Cutlass Supreme from my father in law. The car has 80K miles and runs like a champ, however it has a bunch of small issues on the interior and window gaskets that are keeping it from standing out. He is nearing 90 and I am trying to clean it up for him before he passes to let him ride in it again. He bought it when he retired and it has sat in his garage for about 10 years. I need a few parts so I hope that this community might be able to point me in the right direction. -
Stickman joined the community -
ThatLFXmonteSS replied to ThatLFXmonteSS's topic in General
Yea, after 7 dead 65e’s in multiple different w bodies i was kinda sick of it. Not to mention the 6t70 had 2 extra gears to play with. If it wasn't for the horrible 2.44 fd in the impala transmission it really would've been pretty wicked. Unfortunately ended up getting rid of the car a while ago due to rot. Current owner still has it but it only gets driven for track events. Id like to build another someday with an 06/07 shell and 3.16/3.39 6t out of an suv. Would be much better acceleration/fun wise and the 6t’s OD is still long enough to be perfectly fine on the highway. why didn't i just slap an ls4 in? because everyone either just slaps an ls4 in or an l67. The 6t/ls4 wasn't figured out yet, the ls4 is an absolute pain to work on in that engine bay, and it also just wasn't my taste. I could've done an ls4, at the time we had 2 of them sitting around in donor cars at the yard. I didn't want to lol.
