  2. pwmin
  3. Kdog
    charm.li free forever
  4. Last week
  5. Jscott
    Rough idle/ volt drop
  6. do i leave it white ,or do i use, the red line ?
  7. Earlier
  8. fern_anchor
  9. willowhammer2
    89 olds swaybar
  10. bluecalais79
    A/C Repair - LQ-1
  11. leafyrook67
  12. brightbuck95
    A/C Repair - LQ-1
  13. bluecalais79
  14. bluecalais79
    A/C Repair - LQ-1
  15. bluecalais79
    OIL LEAK - 1994 Cutlass LQ1
  16. This is a great educational video about these motors. You can skip forward to the appropriate section for any questions.
  17. Agreeing with 55 here. Those are reusable...I can send you a video of the process.
  18. Red Menace
    Want to buy
  19. That item is no longer produced, finding a *new* replacement will be on the awkward side. They can be serviced, it's just a mechanical oil filled/spring loaded tensioner.
  20. do you know were i can found the timing belt tensioner for this car the motor is 3.4 lq1 am changing the timing belt but mine is crying oil i need a new on the part number is GM 24503860
  21. It's dusty........but not rusty. Nice climate in Peru.
  22. That's awesome, I often wish my Cutlass could end up somewhere exotic and I could live vicariously through it.
  23. GnatGoSplat
  24. 4doors4flying
  25. Yep, that tracks. The 7727/7730 confusion trips up a lot of people because the guts and calibration family overlap, but the packaging and mounting are what matter in the W-body. For CuttyBawl’s case I’d still verify the MEM-CAL broadcast code before trusting any ADX/XDF combo, especially with a reman ECM sticker involved. For scanning only, the right data stream/mask matters more than the XDF, so if it’s truly a 1990 LH0 he should be looking at $88 stuff first, not just grabbing A109 because it “sort of connects.” For tuning, yeah, starting from $A1 makes sense if you know what you’re changing, but I wouldn’t send a first-timer down that rabbit hole until the idle fault is sorted mechanically. OBD1 will happily let you chase ghosts all weekend, ask me how I know.
  26. 99z34na
  27. Black92GS
  28. 99z34na
