Unfortunately I'm pretty sure things have not gotten any better in the last 5 or so years. Worse at best I suppose. - Yesterday
Sonoma77 joined the community
carkhz316 reacted to a post in a topic: 5.3L LS4 swap into a 95 Oldsmobile Cutlass Supreme SL
awesome!
Mach 5 reacted to a post in a topic: `89 TGP joining the collection
SSWBody joined the community
Route41 joined the community
teemancanada joined the community
Autopia joined the community
Bucksnort543 joined the community
Vette driver joined the community
Wow that car is awesome!
Wow this thing is beautiful!!
GnatGoSplat started following Does anyone have any vacuum harness from any 2.8 V-6 or 3.1 V6?
Dorman does sell universal hard vacuum tubing. You can probably bend it to shape with a heat gun. Years ago, I just put heatshrink tubing over the cracks. Looked like an obvious fudge-fix, but worked fine. -
90sEraWhips started following 3400
i have the rubber connector for the vaccum harness from my 89 2.8 v6 corsica, i’m looking for new hard lines for the vacuum harness now, one of mine has a hole, i can buy the lines if you still have them since you’re going with softer ones, maybe we can trade parts -
babyteef joined the community
torinstone joined the community
That's a daunting swap! Wish I had the balls to do it, but I draw the line at cutting away at a unibody frame that likely wouldn't have won any 1995 IIHS safety awards in the first place. You're all good BCM-wise, there isn't one. -
