  2. Hey! Had my beautiful GTP for bit now and I am just wondering on the available for transmission rebuild kits for the MT. I know I remember seeing they were like basically impossible to get a long time ago but does anyone know of any that have been manufactured again? For the record it is the 3.4L DOHC V6 with a 5 speed, coupe, the only option it came in I believe. I would also like to learn some more about it if anyone has some random facts haha.
  3. Yesterday
  4. Mach 5
    awesome!
  5. Last week
  6. Bake82
  7. rich_e777
  8. SuperBuick
  9. 94 olds vert
    My Turbo 99 Z34 Monte Carlo
    Wow that car is awesome!
  10. White93z34
  11. Earlier
  12. Schurkey
  13. SuperBuick
  14. SuperBuick
  15. babyteef
  16. Ch3vyDude
  17. Ch3vyDude
    Wow this thing is beautiful!!
  18. Psych0matt
    TRW Keyless Entry module
  19. GnatGoSplat
  20. babyteef
  21. mdpierce8
  22. GnatGoSplat
  23. White93z34
  24. mdpierce8
  25. GnatGoSplat
  26. JulienStocola
  27. Bake82
  28. 55trucker
  29. Black92GS
