  2. A reman label really muddies the water, so the broadcast code is the one piece that settles it. A logger that connects with the wrong stream can look believable right up until it sends you chasing nonsense.
  3. Today
  4. Those convertible-specific seals and interior bits can be a real scavenger hunt, but an 80k car that's been garaged is a solid starting point. Getting him one more ride in it would be pretty special.
  5. mossyelk
  6. briskshovel88
    Rough idle/ volt drop
  7. Last week
  8. pwmin
  9. Kdog
    charm.li free forever
  10. Earlier
  11. Jscott
  12. do i leave it white ,or do i use, the red line ?
  13. fern_anchor
  14. willowhammer2
    89 olds swaybar
  15. bluecalais79
    A/C Repair - LQ-1
  16. leafyrook67
  17. brightbuck95
    A/C Repair - LQ-1
  18. bluecalais79
  19. bluecalais79
    A/C Repair - LQ-1
  20. bluecalais79
    OIL LEAK - 1994 Cutlass LQ1
  21. This is a great educational video about these motors. You can skip forward to the appropriate section for any questions.
  22. Agreeing with 55 here. Those are reusable...I can send you a video of the process.
  23. Red Menace
    Want to buy
  24. That item is no longer produced, finding a *new* replacement will be on the awkward side. They can be serviced, it's just a mechanical oil filled/spring loaded tensioner.
  25. do you know were i can found the timing belt tensioner for this car the motor is 3.4 lq1 am changing the timing belt but mine is crying oil i need a new on the part number is GM 24503860
  26. It's dusty........but not rusty. Nice climate in Peru.
  27. That's awesome, I often wish my Cutlass could end up somewhere exotic and I could live vicariously through it.
  28. GnatGoSplat
  29. 4doors4flying
