  2. Red Menace
    Want to buy
  3. That item is no longer produced, finding a *new* replacement will be on the awkward side. They can be serviced, it's just a mechanical oil filled/spring loaded tensioner.
  4. do you know were i can found the timing belt tensioner for this car the motor is 3.4 lq1 am changing the timing belt but mine is crying oil i need a new on the part number is GM 24503860
  5. Last week
  6. It's dusty........but not rusty. Nice climate in Peru.
  7. That's awesome, I often wish my Cutlass could end up somewhere exotic and I could live vicariously through it.
  8. GnatGoSplat
  9. 4doors4flying
  10. Yep, that tracks. The 7727/7730 confusion trips up a lot of people because the guts and calibration family overlap, but the packaging and mounting are what matter in the W-body. For CuttyBawl’s case I’d still verify the MEM-CAL broadcast code before trusting any ADX/XDF combo, especially with a reman ECM sticker involved. For scanning only, the right data stream/mask matters more than the XDF, so if it’s truly a 1990 LH0 he should be looking at $88 stuff first, not just grabbing A109 because it “sort of connects.” For tuning, yeah, starting from $A1 makes sense if you know what you’re changing, but I wouldn’t send a first-timer down that rabbit hole until the idle fault is sorted mechanically. OBD1 will happily let you chase ghosts all weekend, ask me how I know.
  11. 99z34na
  12. Earlier
  13. Black92GS
  14. 99z34na
  15. 55trucker
  16. 99z34na
  17. 55trucker
  18. 99z34na
  19. 99z34na
  20. 99z34na
  21. Black92GS
  22. 55trucker
  23. Black92GS
  24. 99z34na
  25. 96RegalGS
  26. Black92GS
  27. 96RegalGS
  28. Bigbloom420
    I just remove my rear heads. The exhaust we got with two open end wrenches from the top. I did spray some PB blaster but wasn’t 10 minutes after that. I can’t believe I didn’t hear about these hardly having heads blow. My Intake gasket is what it was I’m pretty sure but I guess I decided to go further. It’s a 2000 bonneville l36 series ii
