  2. Today
  3. covefinch9
  4. A reman label really muddies the water, so the broadcast code is the one piece that settles it. A logger that connects with the wrong stream can look believable right up until it sends you chasing nonsense.
  5. Those convertible-specific seals and interior bits can be a real scavenger hunt, but an 80k car that's been garaged is a solid starting point. Getting him one more ride in it would be pretty special.
  6. mossyelk
  7. briskshovel88
    Rough idle/ volt drop
  8. Last week
  9. pwmin
  10. Kdog
    charm.li free forever
  11. Earlier
  12. Jscott
  13. do i leave it white ,or do i use, the red line ?
  14. fern_anchor
  15. willowhammer2
    89 olds swaybar
  16. bluecalais79
    A/C Repair - LQ-1
  17. leafyrook67
  18. brightbuck95
    A/C Repair - LQ-1
  19. bluecalais79
  20. bluecalais79
    A/C Repair - LQ-1
  21. bluecalais79
    OIL LEAK - 1994 Cutlass LQ1
  22. This is a great educational video about these motors. You can skip forward to the appropriate section for any questions.
  23. Agreeing with 55 here. Those are reusable...I can send you a video of the process.
  24. Red Menace
    Want to buy
  25. That item is no longer produced, finding a *new* replacement will be on the awkward side. They can be serviced, it's just a mechanical oil filled/spring loaded tensioner.
  26. do you know were i can found the timing belt tensioner for this car the motor is 3.4 lq1 am changing the timing belt but mine is crying oil i need a new on the part number is GM 24503860
  27. It's dusty........but not rusty. Nice climate in Peru.
  28. That's awesome, I often wish my Cutlass could end up somewhere exotic and I could live vicariously through it.
  29. GnatGoSplat
