96 wheel bearing/hub
Black92GS replied to Andrew T's topic in Brakes/Suspension/Steering/Wheels/Tires
That sounds about right. The SL was the top tier cutlass trim in 1996, but GM being GM....you could spec up a base model to be more loaded than the top trim level, or you could delete enough from an upper level trim to make it less equipped than a base. In some cases, features exist on some vehicles that don't even show as being available for that make/model/trim/year combo. I think it got slightly better as the years progressed....but it still exists to some extent today. -
Interesting. Oldsmobile always had some unique ways of going about option combinations and designations. Thank you ps The ABS light has gone out but did come back on. A scan and physical check at the shop comes up everything is ok. Has been some very low temps and a recent snow storm where I am, for now I'm going hold off on any replacement as it may be just weather related. - Today
I think in 1996 it was just Base and SL on the Cutlass Supreme. But admittedly I'm no expert on that. Cutlass trim was odd there were higher tier ones that were oddly stripped and base ones that were oddly loaded. Generally speaking it meant leather, sunroof, dual zone electronic climate control, and variable assist power steering. Sometimes you'd get the 3.4 DOHC v6. Someone else will correct me, I'm sure. -
Yes, pardon. So there was a base and SL level trim, or was anything above base a SL? Sorry for the added questions, just trying to learn more about the car. -
You mean SL? It's just a trim level. -
55.. and White..., Thanks for the speedy response and information! Still a bit curious, what is the LS option? -
Andrew T reacted to a post in a topic:
not even a difference ABS/non abs on the gen1 front knuckles. the sensor is separate of the wheel hub - why gm couldn't have continued this into the later cars is beyond me. buy whichever brand you determine to be the highest quality or fits within your budget -
55trucker started following 96 wheel bearing/hub
No difference to be had..... for the part # go to Rockauto.......search your vehicle, the hubs are a generalized item, there is no specific item for a premium vs basic car series, just ABS vs no ABS -
Andrew T started following 96 wheel bearing/hub
Looking to replace the the front (driver side I believe) wheel bearing/hub on my 1996 Cutlass 2 door base model. It appears there is a SL also but that the part is the same across the line. Can someone provide a part number and advise as to the SL difference, if any? Thanks
Welcome. -
Pollk joined the community -
Welcome aboard!
Viktor joined the community -
And a spam bot it was.
Here is info for the the swap based on my own experience of swapping my 88 cutlass w-body. 3800 swap w-body From 98/99 Monte Carlo z34/lumina LTZ with 3.8NA Needed - power steering lines (buy new) - Heater hoses (buy new) - Exhaust downpipe (or have one made) - AC system - all lines/parts from the engine bay (compressors can be from the gtp too) Best to have from the Monte Carlo/lumina but not mandatory - engine bay wiring harness - Cv shafts (buy new if you don’t have them) From gtp donor - motor - Trans - Trans cooler lines - rad hoses - Motor mounts - Cv shafts - PCM - Engine bay wiring harness Notes: cv shafts if using an HD trans you need to use the gtp passenger inner with the 1st Gen shaft and outer joint. If you get them from the Monte you can use the stock Monte drivers side. Wiring: if you can’t find the Monte Carlo harness you can use the gtp harnesss, and merge it into the 1st Gen c100 connector. With the Monte harness it comes with the c100 you just need to remove a few pins around and overall much easier but can be hard to find. You’ll need the GM service manuals for your donor harness and your original car to match the c100 connector. If using a Monte harness you will probably want to add the BBV wiring. This will also convert the car to obd2 PCM: you will need to get the vats/security removed(it’s possible it won’t be an issue but be aware it probably will be) and probably want to remove a few other codes. Rad: you could use your original, but the donor gtp rad will be bigger and fits into the chassis. I’d say it’s recommended but not 100% necessary.
