rc_customsli reacted to a post in a topic:
Pollk joined the community -
Welcome aboard!
Valley94Vert joined the community - Yesterday
Viktor joined the community -
And a spam bot it was.
Kdog joined the community -
Luminator98 joined the community - Earlier
dee joined the community -
amended -
Automatic equipped FE3 springs from a 3.4 DOHC car seem to be the stiffest. The manual trans springs are slightly less stiff (as compared side by side, and they have different part numbers). In other words your automatic Z34 has the stiffest ever available factory.
