derekmatthews replied to Oilpatch197's topic in Appearance/Car Care
Bubbling on rear window tint, especially with defroster lines, is a common issue if the film wasn't installed perfectly or if it has aged. The key is a careful removal of the old tint without damaging the heating strips, followed by a precise installation with high-quality materials. OC Tint Solutions in Anaheim and Costa Mesa specializes in handling these tricky rear windows. Their team ensures that all air pockets are eliminated and the tint adheres properly, even around defroster lines. More details on their approach and services can be found on their website. Many local drivers have had success with a professional reinstallation rather than attempting DIY fixes. It’s often the only way to prevent bubbling when the rear defroster is used regularly. -
derekmatthews joined the community -
Here is info for the the swap based on my own experience of swapping my 88 cutlass w-body. 3800 swap w-body From 98/99 Monte Carlo z34/lumina LTZ with 3.8NA Needed - power steering lines (buy new) - Heater hoses (buy new) - Exhaust downpipe (or have one made) - AC system - all lines/parts from the engine bay (compressors can be from the gtp too) Best to have from the Monte Carlo/lumina but not mandatory - engine bay wiring harness - Cv shafts (buy new if you don’t have them) From gtp donor - motor - Trans - Trans cooler lines - rad hoses - Motor mounts - Cv shafts - PCM - Engine bay wiring harness Notes: cv shafts if using an HD trans you need to use the gtp passenger inner with the 1st Gen shaft and outer joint. If you get them from the Monte you can use the stock Monte drivers side. Wiring: if you can’t find the Monte Carlo harness you can use the gtp harnesss, and merge it into the 1st Gen c100 connector. With the Monte harness it comes with the c100 you just need to remove a few pins around and overall much easier but can be hard to find. You’ll need the GM service manuals for your donor harness and your original car to match the c100 connector. If using a Monte harness you will probably want to add the BBV wiring. This will also convert the car to obd2 PCM: you will need to get the vats/security removed(it’s possible it won’t be an issue but be aware it probably will be) and probably want to remove a few other codes. Rad: you could use your original, but the donor gtp rad will be bigger and fits into the chassis. I’d say it’s recommended but not 100% necessary. - Yesterday
Grand Prix Front bumper on Lumina
Kdog joined the community - Last week
primergray started following G1 Rear Strut Tower Rot Prevention & Restoration Efforts
dee joined the community -
amended -
I gotcha. Just was wondering if there was something beefier for the W-Body I should look for. - Earlier
Not lower. Just have the best/highest spring rating chevy offered.
