91lumina5.3 joined the community - Last week
Brake upgrade completed
Given what you're doing with the car going bigger can't hurt, when you say you've spun out the car because of the brakes is that because the tail is loose & breaks free in a corner under braking? Being an FWD car the tail is more likely to follow the front where the front goes as the the back end is not driving the car. Something else to consider is the factory camber the cars alignment is set to, it's not slalom considered at all, the fronts are set to a .8 positive camber setting while the rears are at just on the + side of 0. If you were to go to a negative setting on both the front & rear I'm sure you see a far more responsive & more neutral response. -
I'm curious how well this does, I know my usecase isn't at all what these cars were designed for but on track the weakest link for these cars are the stock brakes. I have a '96 and even with the larger rotors they get really hot, I'm using pretty aggressive pads and they get toasty really easily, I've spun the car and gone off track because of it. I always just assumed that the next step would be to figure out how to fit larger calipers on the front and rear that can also take better pads. -
55trucker started following What's the reset process for a new accelerator pedal on an '08 3.8L? and Brake upgrade completed
Well, I completed my front brake upgrade, gone are the 10 1/2" rotors & in their retired place are a pair of 12" rotors. My approach for this was to maintain the original W calipers & just install larger dia rotors in the same manner that GM did when replacing the 10 1/2" rotors with 11 1/4" rotors. The W calipers are more than adequate on their own merits. The 11 1/4" calipers are pushed further out from center by a later design in the caliper bracket adapter. Seeing as I didn't want to purchase & then alter the 95-96 adapters I reconfigured what I had on the car. To do this alteration one has to remove the adapter that is welded to the steering knuckle. One has to cut away the outer section of the *ears* that the caliper bracket is bolted to. I sourced a length of 1/4"x2"x 12" A36 hot rolled mild steel flatbar, this bar is already stronger than the stamping of the adapters & the flatbar is thicker than the adapter by .050 thou. Starting with the drivers side which being done 1st served as the guinea pig for any mistakes I know I would make. I cut off the adapter, gave it a blasting, laid it out on a workbench & proceeded to mock up what the new longer *ears* would look like to get what was needed. Out of the 12" of flatbar I cut 4 *ears* each the same size, from there I laid out on each one the location where I would need to drill the 9/16 hole for the thru bolt. The *ears* have to be shaped into a circular manner on their edge so as to fit into the valley on the backside of the caliper brackets & be able for me to pivot them to get the appropriate angle before tacking them to the adapter. This mod requires that the new *ears* be overlaid onto the backside surface of the adapter. The new rotors *hat* is 1/4" deeper than the original rotor so the need for 1/4" flatbar to move the caliper back inward to get the proper location for the new rotors. Now the adapter has to be fastened back into place on the knuckle behind the hub assembly, install the new rotor onto the hub & lock it into place with a couple of wheel nuts, bolting loosely the *ears* to the cast caliper bracket I can now place the bracket over the rotor to get an approx location where the position will be that is the same as the original caliper was placed. I now install the caliper & the new pads into the bracket & slide the entire assembly over the new rotor, getting an accurate height position for the caliper on the rotor I now need to check that all of the caliper pad is contacting the rotor face. Seeing as the 12" rotor has a larger diameter one needs to make sure that the outer edge of the rotor will clear the inside edge of the stationary bracket but get all of the caliper pad on the rotor surface. I had to remove the brackets & mount them into a bench vise an carefully remove approx .030 tho of surface inside the very upper edge of the upper & very bottom edge of the lower portion to expand the radius to get the needed rotor clearance as it spins inside the stationary bracket. After doing this I can now reinstall the assembly, position the assembled caliper & bracket, position the new *ears* over the cut off ends of the adapter, tighten down the bolts to hold the *ears* where I want them & now tack the upper & lower *ear* into position. I repeated this same procedure for the right side but it went much faster seeing that after completing the left side I now have a template use for the right side. The welding was simple, remove everything from the car, bolt the cast caliper bracket to the adapter to prevent the adapter from warping while welding, mount them into a vise and run the beads, a flat downhand is best for this, the 71M wire puts down a nice wide bead to get maximum coverage for strength in a single pass. This welding procedure requires a minimum of a 200 amp mig, the wire I used was a deep penetration fabrication flux core wire for argon/c02 for heavy fab work such as construction/ship building. A 70S is not recommended. After getting everything assembled back together the last thin to cover is the new rotors hub opening, the W hubs are 70mm dia, the new rotors are 71 mm opening, this means that a 1mm shim is required to slide into the center of the rotor to properly center it over the hub. This was relatively easy, I pick up some 1mm stainless sheet steel & cut two shims 1/4" wide & to length & slipped them into the center of the rotor around the hub stub, then slide the rotor onto the hub. Worked perfect. It's been 2 weeks now since completion, after bedding in the new pads I have done some mild to moderate brake stops, working up to a few panic stops. The difference is instantly noticeable. The car just hauls down to a stop in a much quicker, shorter amount of time. Now since a few years ago when I did the booster upgrade the pedal feel at that time was instantly changed. Going from a hard, less than desirable *no assist* feel to a one can literally stop the car by using ones hand on the brake pedal, the booster supplies so much assist the pedal is like a feather to press. The pads because of their shape do not cover the entire rotor contact face, approx 70% of the rotor surface is made use of & that's the outer portion of the rotor. I have to believe that the smaller 11 1/4" rotors see this as well, not having had any in my hands to compare the contact area with the 10 1/2" rotors I'm pretty sure that THOSE rotors may have a larger dia hat area that reduces the contact area to something similar to the 10 1/2" rotors, these Ford Crown Vic rotors have a *hat* area that is the same as the 10 1/2" rotor hat. All in all...well worth my time & effort & what did it cost me? ...the price of a pair of new rotors & pads & a length of flatbar.
ernie22lord joined the community -
ceramicheper joined the community -
Cnuts24 joined the community - Earlier
cold joined the community -
Ok, yes, it does still function without it. I installed the new shift interlock solenoid, and it worked great. Too great. When i tried running the shifter through the gears, it worked fine. Until I tried to pull the key out of the ignition. It was stuck like glue. I tried every trick I knew and a few other people knew. Key wiggling, shifter pushing, steering wheel cranking to the far sides, disconnecting the battery, pushing on the interlock cable, pulling on the interlock cable, and a few more I can't remember right now. After leaving the car in the parking lot with its key in it last night (hung a roll of black gorilla tape over the key. It wouldn't go anywhere if they did get in and start it, anyway). Today I pulled the dash apart to try to get to the ignition switch so I could pull the tumbler cylinder out and work on it that way. As I was triggering the cable, I watched it as i pulled the shifter trigger button that releases the shift interlock solenoid. I reached down and grabbed the dead end of the cable on the back of the rocker that pulls it, I found that there was enough slack in the cable that i could pull it another 3/32" more cable past the point of where the rocker pulled it to. I tried pulling the key out and it came out! Apparently, the cable/wirehas stretched. I tried to figure out a way to crimp something on or adjust the rocker that pulls the cable, thinking maybe a lead fishing sinker crimped on there may work. But then I thought about the grandkids having it come uncrimped or slide up and going back to square one, so I disconnected the ignition switch end of the cable from its housing and it worked. I then thought, well, if that works, I wonder if it even needs the solenoid on there, so I tried it with the solenoid off. Still works. I checked for dash warning lights, went through the gears and it still functions fine. So the $80 solenoid is going back for a refund. I was a little worried about the car starting in gear, but it won't. It will start in park and neutral, but not in any of the driving gears, including reverse. I'm going to get them a new cable and install it sometime, but for now, it's fixed. Sort of. At least I don't have to buy a $200 ignition tumbler and have it recoded. Now, I just have to figure out what's wrong with the tranny. The shift cable is good and is switching through all the positions at the arm on top of the transmission, but it's not engaging in any gears and neutral isn't letting me role any. But at least the key isn't stuck anymore and I think I've fixed the problem with the shifter. Onward, to the next problem! -
I'm working on my grandson's '08 GP and I need some advice. He was starting to have problems shifting out of park and was also having 'reduced power' (limp mode) until it got so bad he called me for help. From what I've learned, the possible culprits for the shifting problem are the brake pedal position sensor, the shift interlock solenoid, and that the accelerator pedal may be one reason for the limp mode. I know the throttle body might cause this too, but I replaced that about 2 years ago with a GM OEM part. I've put a new brake pedal position sensor on, and a new accelerator pedal/sensor just in case. I have a new scan tool arriving today to calibrate the brake pedal sensor. As of now, after putting those parts in, the car starts, the shifter moves (sometimes), but when I put it in any gear it revs but doesn't kick into gear. I'm hoping this will clear up after I re-set the brake sensor. My question is about the shift interlock solenoid. After not finding new ones anywhere, I ordered a used complete shifter with a solenoid on it after asking the seller if the solenoid was for sure good. He said it was, and it's on the way. But if I remove the interlock solenoid from the shifter, would everything still work as normal (aside from the fact that the shifter would no longer need to be in park to complete the start up? Is there anything in the circuit between the brake pedal sensor and the shift interlock solenoid that would keep the car from starting or running correctly? I've already pulled the solenoid but didn't try to start it and check it yet. The car is sitting in the high school parking lot where my grandkids are students. Anyway, the scanner comes in today and the "new" shifter assembly will be here in a few days. I'm wondering if I get the brake sensor calibrated and can get it running and shifting if it would be safe (me driving) to drive back to my house to finish the job. Also, if anyone has any suggestions about troubleshooting the reduced engine power/limp mode, I'd appreciate any help or comments on that. Thanks for any help on this. Lee -
showme joined the community -
