What's the reset process for a new accelerator pedal on an '08 3.8L?
My grandkids '08 went into limp mode (reduced power) and I've been throwing parts at it to try to fix it. I installed a brake pedal position sensor and had it calibrated, but it's still showing reduced power, so I installed a new accelerator pedal. But after I did, the car's idle was crappy. It sounded weak and was revving up and down (not bad, but noticable),  so I figured I had gotten a defective new pedal and removed it and put the old one back on and the idling problem disappeared. While checking out videos on some other GP subjects, I came across one for resetting accelerator pedals by turning the key to accessory, slowly pushing the pedal to the floor and holding it for 10-15 seconds and letting it up slowly. But the guy said at the end of the video that each vehicle has it's own sequence for resetting, so I need to know if anyone can tell me the correct procedure for doing this on our 2008 Grand Prix 3.8. I want to try putting it in again and see if it will work correctly by resetting it, which I didn't do last time. Thanks for any ideas or comments. Lee
Edited by showme
So... do you know how to know how to recalibrate the accelerator pedal position sensor or not? I'm not buying the manual you mentioned because as soon as I get this thing fixed, they're selling it. And I need to get it done asap. I was looking for an answer to the question asked.
As I posted if you want to do your own repairs you'll need a service manual to guide you, the vehicle is an '08, you should be using a proper scanner (not a reader) such as a Snap-On/Matco/OTC to recalibrate the throttle pedal, without that you may not be successful.
You CAN try the below......but #4 is where you may fail
1 Turn the ignition to ON (do not start) and wait 3 seconds.
2 Turn the ignition OFF and wait 10 seconds.
3 Turn the ignition back to ON (do not start) and wait 3 seconds.
4 Depress the accelerator pedal all the way to the floor and release it 5 times within 5 seconds.
5 Wait 7 seconds then depress the accelerator pedal and hold it for approximately 20 seconds until the check engine light stops flashing and stays on solid.
6 Release the accelerator pedal and start the engine. Let it idle in park for about 3 minutes.
