  2. Today
  3. That video is one of those rabbit holes where you start with a tensioner and end up learning the whole LQ1 timing setup. Pretty handy to have around.
  4. Yesterday
  5. covefinch9
  6. A reman label really muddies the water, so the broadcast code is the one piece that settles it. A logger that connects with the wrong stream can look believable right up until it sends you chasing nonsense.
  7. Those convertible-specific seals and interior bits can be a real scavenger hunt, but an 80k car that's been garaged is a solid starting point. Getting him one more ride in it would be pretty special.
  8. mossyelk
  9. briskshovel88
    Rough idle/ volt drop
  10. Last week
  11. pwmin
  12. Kdog
    charm.li free forever
  13. Earlier
  14. Jscott
  15. do i leave it white ,or do i use, the red line ?
  16. fern_anchor
  17. willowhammer2
    89 olds swaybar
  18. bluecalais79
    A/C Repair - LQ-1
  19. leafyrook67
  20. brightbuck95
    A/C Repair - LQ-1
  21. bluecalais79
  22. bluecalais79
    A/C Repair - LQ-1
  23. bluecalais79
    OIL LEAK - 1994 Cutlass LQ1
  24. This is a great educational video about these motors. You can skip forward to the appropriate section for any questions.
  25. Agreeing with 55 here. Those are reusable...I can send you a video of the process.
  26. Red Menace
    Want to buy
  27. That item is no longer produced, finding a *new* replacement will be on the awkward side. They can be serviced, it's just a mechanical oil filled/spring loaded tensioner.
  28. do you know were i can found the timing belt tensioner for this car the motor is 3.4 lq1 am changing the timing belt but mine is crying oil i need a new on the part number is GM 24503860
  29. It's dusty........but not rusty. Nice climate in Peru.
  30. That's awesome, I often wish my Cutlass could end up somewhere exotic and I could live vicariously through it.
