  2. Schurkey
  3. Yesterday
  4. SuperBuick
  5. SuperBuick
  6. babyteef
  7. Ch3vyDude
  8. Last week
  9. Ch3vyDude
    My Turbo 99 Z34 Monte Carlo
    Wow this thing is beautiful!!
  10. Psych0matt
    TRW Keyless Entry module
  11. GnatGoSplat
  12. babyteef
  13. mdpierce8
  14. GnatGoSplat
  15. White93z34
  16. mdpierce8
  17. GnatGoSplat
  18. JulienStocola
  19. Bake82
  20. 55trucker
  21. Black92GS
  22. so this is my first post here on this forum and i don't quite know what to get out of it, as you saw I'm attempting to get all pieces together to get a 5.3L LS4 with the transmission, all wiring ecu tcm is all connected, the entire subframe setup was taken down from a impala to swap into my 95 Oldsmobile Cutlass Supreme SL. Being a obd 1 car i don't know if its only the ecm/ecu that runs the tranny or if there's a bcm ( body control module) that goes with it, that being said this car was given to me as a gift from my grandfather who recently passed, so if you guys are tryna convince me to start with something else forget it, ive seen the motor go into the car already and the guy who posted it here was even brave enough to get a 4t80 inside along with it. my main question is what ecu and standalone kit would be best used for this setup as i only see all other ecu's being compatible with the other LS engines instead of this one
  23. Earlier
  24. GnatGoSplat
  25. Yep, I've probably removed the bezel a hundred times across 3 Cutlass Supremes and it's never broken. It's hard plastic and seems brittle, but it's actually quite durable.
  26. Good point, it may. I'll keep an eye on it. My feeling is at this point it will outlast that car. It will be interesting to see and I'll check in after a while to let the members know. Thanks for the feedback
  27. Applying grease to an area subject to road-splash and dust entry may be counterproductive.
  28. The glas leaf would be in an *ok* situation if the ends were curled up slightly to allow the end of the leaf to lay flat in the knuckle opening *without* the rubber isolators, then the friction between the end of the leaf & the nylon pads would be lessened.
  29. That is correct 55...., It has been a bit confusing trying to figure out just the blocks, just the rubber pads, both? To me bother would lift the rest too high and the rubber pads would wear through eventually. I am thinking the blocks will last for a long time, maybe longer the the car, who knows. It has been an interesting experience and I've learned far more about W bodies that I thought I'd ever learn lol. Still curious about actual parts numbers to build the rear coil overs. Thanks for the feedback
