  2. hazelspindle3
    New member with 98 lumina
  3. Today
  4. hazelspindle3
  5. calmspindle6
    New to this place. Hello.
  6. That video is one of those rabbit holes where you start with a tensioner and end up learning the whole LQ1 timing setup. Pretty handy to have around.
  7. Yesterday
  8. covefinch9
  9. A reman label really muddies the water, so the broadcast code is the one piece that settles it. A logger that connects with the wrong stream can look believable right up until it sends you chasing nonsense.
  10. Those convertible-specific seals and interior bits can be a real scavenger hunt, but an 80k car that's been garaged is a solid starting point. Getting him one more ride in it would be pretty special.
  11. mossyelk
  12. briskshovel88
    Rough idle/ volt drop
  13. Last week
  14. pwmin
  15. Kdog
    charm.li free forever
  16. Earlier
  17. Jscott
  18. do i leave it white ,or do i use, the red line ?
  19. fern_anchor
  20. willowhammer2
    89 olds swaybar
  21. bluecalais79
    A/C Repair - LQ-1
  22. leafyrook67
  23. brightbuck95
    A/C Repair - LQ-1
  24. bluecalais79
  25. bluecalais79
    A/C Repair - LQ-1
  26. bluecalais79
    OIL LEAK - 1994 Cutlass LQ1
  27. This is a great educational video about these motors. You can skip forward to the appropriate section for any questions.
  28. Agreeing with 55 here. Those are reusable...I can send you a video of the process.
  29. Red Menace
    Want to buy
  30. That item is no longer produced, finding a *new* replacement will be on the awkward side. They can be serviced, it's just a mechanical oil filled/spring loaded tensioner.
