Jscott Posted September 25 Report Posted September 25 Hello friends. Another one for you. My 1990 cutlass 3.1. Has a rough idle when it warms up. Replaced a lot of items and even a charcoal canister. Thinking the evap is bad. Which it was anyway. But the car starts acting up when it’s in gear and idling with foot on brake. Which I also noticed as my foot is on brake the engine kinda surges and I see my volt gage dip up and down a little. But enough to make the engine not perform as it should. I have to mention that I have a power master 3 brake system. Not a fan. Any ideas would be appreciated. Quote
briskshovel88 Posted October 2 Report Posted October 2 Jscott said: Hello friends. Another one for you. My 1990 cutlass 3.1. Has a rough idle when it warms up. Replaced a lot of items and even a charcoal canister. Thinking the evap is bad. Which it was anyway. But the car starts acting up when it’s in gear and idling with foot on brake. Which I also noticed as my foot is on brake the engine kinda surges and I see my volt gage dip up and down a little. But enough to make the engine not perform as it should. I have to mention that I have a power master 3 brake system. Not a fan. Any ideas would be appreciated. That Powermaster can load the electrical system pretty hard when it cycles, and the voltage dip could be dragging the idle down with it. A weak ground or tired alternator would make that whole combo a lot more noticeable. Quote
Jscott Posted October 9 Author Report Posted October 9 Thank you for your advice!! I really appreciate it. Quote
Amanita Posted October 9 Report Posted October 9 On 9/24/2026 at 9:16 PM, Jscott said: Hello friends. Another one for you. My 1990 cutlass 3.1. Has a rough idle when it warms up. Replaced a lot of items and even a charcoal canister. Thinking the evap is bad. Which it was anyway. But the car starts acting up when it’s in gear and idling with foot on brake. Which I also noticed as my foot is on brake the engine kinda surges and I see my volt gage dip up and down a little. But enough to make the engine not perform as it should. I have to mention that I have a power master 3 brake system. Not a fan. Any ideas would be appreciated. If you turn the headlights on and apply the brake do you notice any of the needles wiggle a little bit? I had that happen to me while driving and it turned out to be the alternator going bad, had to swap both that and the battery. Quote
