pwmin Posted September 11, 2025 Report Posted September 11, 2025 I have a couple questions about rear view mirrors and I'm trying to dig through they recent posts in the whatever thread and find the post with all the mirrors, but I'm having a hard time finding that and wading through the posts. I put a mirror in the 95 Z34 that had map lights, but it's too loose to live with my subs plus I had it wired incorrectly so the lights were controlled by the interior lighting and not the swtiches on the mirror. Anyway, I'm just interested in map lights and auto-dim and having a set screw, not the stupid press-fit crap. I will probably just go to the local U-Pull-and-Pay. What vehicles can I use and how should I have it wired? I have some terrible pictures to share. Right now I have one with auto-dim just so I didn't have to deal with a falling mirror, but I don't have it wired correctly for that either. I think the one that's in it is an 051330 and the one I had in it is a 3C1215, but neither are the ones I really want. The first 3 pictures are of the one I had in there with map lights only, the second 2 are what's in there now and the last 3 are of one that came out of my Grand Prix for wiring reference, I suppose. Quote
pwmin Posted September 11, 2025 Author Report Posted September 11, 2025 (edited) https://rearviewmirrorstore.com/products/gentex-auto-dimming-mirror-with-led-map-lights I think this is the one. Anyone know what cars these come from and how to wire them? I guess I could just buy from here, but it would be a lot cheaper at the junkyard. Looks like a bunch of GM and Chrysler products, but I can't find an actual list. pinout: https://www.the12volt.com/installbay/forum_posts.asp?tid=138415 maybe why mine didn't work correctly: https://ls1tech.com/forums/wiring-stereo-electronics/1927323-gentex-221-a.html Edited September 11, 2025 by pwmin Quote
RareGMFan Posted September 11, 2025 Report Posted September 11, 2025 (edited) rearviewmirrorstore.com is actually my site. I was just checking on visitors for the day, and I saw someone was directed there from w-body.com. I was like.....what?! Then I came here and found this. That's a pretty rare mirror you linked to. As far as I know, they were an exclusive option in the Dodge Stratus, and as you can imagine, there's not a lot of those in the junkyards anymore. It's what I call my "grand daddy of them all" mirror, as it has pretty much every feature other than a back up screen, thus the price. You're actually pretty limited on choices if you want auto-dimming with map lights. Donnelly made them, which were even found in 2nd gen Regals, but Donnelly mirrors are garbage. The auto-dimming gel is pretty much guaranteed to break/leak at some point, and I'm guessing the gel must be acidic or something, because eventually, they start deforming/eating through the plastic housing of the mirror. I have seen this time and time again in the junkyards and in the w-body community. Have helped several GTP owners switch from their Donnelly (no map lights) to that mirror in your last pic. Very easy swap. Another option is the optional 1st gen Sebring convertible mirror. Same mirror was available in the mid-'00s Lincoln Continental and Olds Intrigue GLS, except those had a compass as well. The problem with any of those, as me and Sean have talked about numerous times on this site, is that they require a BCM to kill power to the mirror after X amount of minutes. Otherwise, those mirrors will have a continuous draw on the battery. Enough so that they could kill the battery if you don't start the car after a few days. These are the mirrors I'm talking about: https://rearviewmirrorstore.com/products/gentex-auto-dimming-mirror-with-led-map-lights https://rearviewmirrorstore.com/products/gentex-auto-dimming-mirror-with-led-map-lights-compass There IS another older option that many don't know about for auto-dimming and map lights. They were an exclusive option for the '90s Chevy Caprice and Buick Roadmaster, so they'd be period correct for your Z34. Only downfall is I believe they use the tension spring mounting instead of a torx screw. I have a few that are still sitting around. This is what they look like: Edited September 11, 2025 by RareGMFan rich_e777 1 Quote
pwmin Posted September 11, 2025 Author Report Posted September 11, 2025 So, the one I linked to (from your store?) is that the one you have to kill power to? If I can use that one, I might just buy it from you, then. I hate removing the tension ones from the junkyard, but I do have the tool. Yeah, the Donnolly ones from Regals always fall down. The one from my GP was falling down, but they are easy to find. I guess it doesn't matter too much if it has the compass and/or temp, I just don't need to have them. Since the Monte didn't have an OHC, I pretty much need one with the MAP lights and the auto-dim is a nice bonus for sure. Quote
RareGMFan Posted September 11, 2025 Report Posted September 11, 2025 The one YOU linked to from my store (the "fully loaded" mirror), I'm not sure about to be honest. I know the 2nd gen Stratus had a BCM that controlled the courtesy lights, but I don't know if they killed power to them after the car is off. The 2 that I linked to in MY post we know definitely need a BCM to kill power to them, and ever since discovering this, I've been hesitant on suggesting any LED map light mirrors to people with older cars that might not have a BCM that controls the courtesy lights. I suppose a work around for any of the map light mirrors would be to not power the one wire that's supposed to run to your courtesy lights, and just run the other wire to a power source that only comes on with ignition or accessories (your old mirror should already be wired for that; just have to figure out which wire it is). But that would mean the map lights won't come on when you open your doors or turn on the courtesy lights. They would only come on independently when you press the map light buttons on and off. If that doesn't bother you, then you can make those mirrors work. Also, just a heads up that the "fully loaded" mirror you linked to has outside temperature which will require a temp sensor to be installed somewhere by your front bumper and then running 2 wires back to the mirror. This is true for any mirror with the outside temp feature. I know you don't like the tension ones, but if you want to maintain the courtesy light function of the map lights, then the one in my pics is probably your safest bet to avoid any constant draw issues. I'm not even 100% positive on those because I just looked it up and Gemini says even the mid-'90s Caprices/Roadmasters did have a BCM and they controlled the courtesy lights, but given their age, I doubt those mirrors have a constant draw on them that's controlled by the BCM. Quote
pwmin Posted September 12, 2025 Author Report Posted September 12, 2025 I thought the one I linked and the first one you did were the same one. I could probably deal with the MAP lights only coming on with the buttons on the mirror. I guess temperature in the mirror would be a good thing to have and easy to add a sensor. One of these days I suppose I can go the the yard and go through the aisles and just look for mirrors. If I know what vehicle I'm looking for, I can check the inventory ahead of time, though. There has to be someone somewhere that has made a list of what vehicles came with what mirrors. I do have an OHC from a Grand Prix with MAP lights. I wonder how much of a hassle that would be to fit in the Monte. Quote
RareGMFan Posted September 12, 2025 Report Posted September 12, 2025 The 2 that I linked to are the mid-'00s auto dimming with LED map lights (with and without compass). No HomeLink, no outside temp. The no compass is from a 1st gen Sebring convertible, and the compass one is from the Olds Intrigue GLS (has to be that trim level). There's an even rarer version of those mirrors that had temp as well, but those were only available in mid-'00s Wranglers and Range Rovers. Not something I'm going to come across in a self-service yard very often. I DID find one and only one once...in a Regal of all things. Obviously added in by a previous owner. I was beyond shocked and ecstatic. It was the first mirror to sell when I launched the website. Doubt I'll ever find another one. The one you linked to (the "fully loaded" one) is only found in the 2nd gen Dodge Stratus, thus the amber colored display. If you end up getting that one, you can always try wiring everything up like normal and see if there's a draw on the battery while the car is off. If there is, you can always disconnect the courtesy wire so nothing is reliant on a BCM and just leave the constant power wire so the lights can be turned on/off individually when you need them. I can't see anyone putting a list together for all this because it would be quite the daunting task. Even for me, after all these years of hitting the yards and coming across all kinds of mirrors, I'll run into something I'm not familiar with. I remember years back when I found an Intrigue GLS, but was disappointed to see it had OnStar. I looked underneath it for the hell of it and found it had the same LED map lights as the non-OnStar auto-dimming mirrors! Did not know that was a thing all those years. Think I've only ever found 2 like that. Quote
pwmin Posted September 12, 2025 Author Report Posted September 12, 2025 I had written out a reply on my work laptop, but I guess I didn't hit send. I will check Monday and resend it cuz I don't know what I said Quote
pwmin Posted September 17, 2025 Author Report Posted September 17, 2025 just putting together a short list of potential suitors when I go back to the junkyard 2001? - 2006? Dodge Stratus 1995?1998 - 2002 Lincoln Continental 1998-2002 Olds Intrigue GLS (+ compass) 1996-2000 Chrysler Sebring convertible 1991-1996 Chevy Caprice, Buick Roadmaster (tension mount) Out of those, these are the only ones they have. Maybe I should go check those. 2004 DODGE STRATUS 6/30/2025 63 Photo*Details 2005 DODGE STRATUS 8/7/2025 73 Photo*Details 2006 DODGE STRATUS 9/9/2025 56 Photo*Details Quote
pwmin Posted September 19, 2025 Author Report Posted September 19, 2025 They must have junked two of them because there were only 2 when I looked before I went today. They were both base models, unfortunately. However, I did find a Sebring that I didn't know was there. Just need to figure out how to wire it now. Quote
pwmin Posted September 19, 2025 Author Report Posted September 19, 2025 I had the power wires backwards. Not sure if the auto dim feature works and/or if I'll have to add another wire, but the map lights are working. Hopefully it doesn't kill my battery Quote
RareGMFan Posted September 19, 2025 Report Posted September 19, 2025 This is the wiring diagram for that mirror. The only wire I don't include is pin 3, which disables auto-dim in reverse. Pretty useless feature IMO, so rather than adding more complication for my customers (have to tap into a reverse light power source), I just remove that pin from the connector. Quote
Black92GS Posted September 19, 2025 Report Posted September 19, 2025 (edited) 45 minutes ago, pwmin said: I had the power wires backwards. Not sure if the auto dim feature works and/or if I'll have to add another wire, but the map lights are working. Hopefully it doesn't kill my battery If I understood correctly, the battery drain issue with the Intrigue version was due to the heater grid in the compass VFD being powered by the always on power lead for the map lights...which was ultimately controlled by the BCM in its original application. Since your mirror doesn't have a compass, you might not experience the same drain issue. Edited September 19, 2025 by Black92GS Question removed as it was already answered :) pwmin 1 Quote
RareGMFan Posted September 19, 2025 Report Posted September 19, 2025 Positive/power for the compass is shared with the auto-dimming wire, meaning a compass on any auto-dimming mirror requires no additional wiring. That wire is run to a source that only comes on with power/ignition. The LED map light mirrors have an issue because one of the wires is tapped into a courtesy light source so that they can come on with the rest of the lights when you open the doors or turn on interior lights. That is apparently where the problem lies, because the courtesy lights on '00ish and up vehicles were quite often controlled by a BCM, so without that, the LED map lights continuously draw a small amount of power (about the equivalent to a 194 bulb according to @GnatGoSplat). Not positive if that applies to these Sebring/compass-less mirrors, too, but it would be hard to imagine they had 2 virtually identical mirrors with different circuitry in them. Quote
pwmin Posted September 19, 2025 Author Report Posted September 19, 2025 2 hours ago, RareGMFan said: Positive/power for the compass is shared with the auto-dimming wire, meaning a compass on any auto-dimming mirror requires no additional wiring. That wire is run to a source that only comes on with power/ignition. The LED map light mirrors have an issue because one of the wires is tapped into a courtesy light source so that they can come on with the rest of the lights when you open the doors or turn on interior lights. That is apparently where the problem lies, because the courtesy lights on '00ish and up vehicles were quite often controlled by a BCM, so without that, the LED map lights continuously draw a small amount of power (about the equivalent to a 194 bulb according to @GnatGoSplat). Not positive if that applies to these Sebring/compass-less mirrors, too, but it would be hard to imagine they had 2 virtually identical mirrors with different circuitry in them. I guess we'll see if it drains it. I can check for a draw, too. I have a circuit breaker I can always turn off when it's going to sit. Quote
Black92GS Posted September 20, 2025 Report Posted September 20, 2025 5 hours ago, RareGMFan said: Positive/power for the compass is shared with the auto-dimming wire, meaning a compass on any auto-dimming mirror requires no additional wiring. That wire is run to a source that only comes on with power/ignition. The LED map light mirrors have an issue because one of the wires is tapped into a courtesy light source so that they can come on with the rest of the lights when you open the doors or turn on interior lights. That is apparently where the problem lies, because the courtesy lights on '00ish and up vehicles were quite often controlled by a BCM, so without that, the LED map lights continuously draw a small amount of power (about the equivalent to a 194 bulb according to @GnatGoSplat). Not positive if that applies to these Sebring/compass-less mirrors, too, but it would be hard to imagine they had 2 virtually identical mirrors with different circuitry in them. I recall @GnatGoSplat commenting that on the specific mirrors from the Intrigue, the constant power for the map lights kept the VFD grid powered on, and visible in the dark, and that it was the cause of the drain when running without a BCM. I also seem to recall there being a fix where the grid was either disconnected, or possibly rewired internally to run off the switched power feed instead. If I had to guess, the constant power actually powers the entire mirror, with the switched powers used moreso as controls to turn on and off the courtesy lights and the mirror/compass. If the grid on the compass display was the main draw on the intrigue mirror, the lack of it on the Sebring mirror might mean there is much less of a draw, even if the circuitry is otherwise identical. pwmin 1 Quote
RareGMFan Posted September 23, 2025 Report Posted September 23, 2025 OK, I've been racking my brain trying to think of how that could be the case since auto-dimming and (if applicable) compass/temp displays run off the same positive wire on all Gentex mirrors (see the wiring diagram I posted a few replies ago). But I just remembered something I keep forgetting about these mirrors until I bench test them. Yes, it follows the same wiring pinouts as all other 7-pin mirrors, BUT...unlike any other mirror, when I connect pin 1 (power to auto dimming, and if applicable, compass/mirror display), and pin 2 (ground), the mirror won't power on at all. Neither the auto-dimming NOR the display will work until I connect the map lights constant power wire to power, so there's definitely something different about the internal circuitry of these particular mirrors, and that applies to both with and without compass (just tested the without compass mirror like the one pwmin just got, and it does the same thing; auto-dimming doesn't work until the map lights constant power wire is powered). So this doesn't only impact the VFD, as the wire that powers on the VFD and the auto-dimming are the same. This just led me to test the "fully loaded" mirror above, which also has LED map lights, because I couldn't remember off the top of my head if it did the same thing. It did. Connecting power to the auto-dimming/display wire and ground (the equivalent to just pins 1 and 2 in the 7 pin mirrors) didn't do anything. I had to connect the constant power wire for the map lights in order for them to kick on. Connecting the HomeLink power and ground allowed the HomeLink to work, though. I'm guessing this holds true for any other map lights auto-dimming mirror, which is really a shame. These could be useful in a LOT of cars, but the need for a BCM with battery rundown protection feature eliminates them as an option for many older cars, especially if they're not a daily driver. Sucks. pwmin 1 Quote
