89-W-Body-Regal Posted January 31, 2024 Report Posted January 31, 2024 (edited) I am looking for a Coolant Level sensor that mounts onto the radiator on the top left side of the radiator. I was able to find one NOS GM part made by AC DELCO at a Chevy Dealership last year. I replaced it a couple months ago and the low coolant light is still on. I was hoping the sensor would shut off the light like it should when the coolant is not low. The reason why I replaced it in the first place was because the low coolant light kept going on and off. It must have had a short circuit in it. I replaced the sensor in 2020 when the low coolant light was on then and the light never came back on. The light came back last year and I thought maybe it was the sensor again like before because the coolant is staying full but the light is still on saying coolant is low. After I replaced it the light never went out and the coolant is full. GM has discontinued this part number by GM 14094922. It was suspended to part number 8859353. I was going to purchase one of the remaining ones off ebay. But none of the sellers will offer free returns if the sensor is defective and has to be returned. So I was wondering if anything aftermarket that is reliable has the sensor available so I can get warranty. Keep in mind those parts on ebay are nos. They can't replace it if the part is defective out of the box because they aren't available to get an replacement. Edited January 31, 2024 by 89-W-Body-Regal 92Lumi 1 Quote
Schurkey Posted February 5, 2024 Report Posted February 5, 2024 Low coolant light was lit up on my '92 for a couple of years. Then it went out. I wouldn't guarantee that it's the sender at fault. Could just as easily be the wire harness with bare wire, or a fault in the instrument cluster. I would absolutely verify the harness before I crammed-in another sensor, whether from GM or an aftermarket sensor from a local parts store. 92Lumi 1 Quote
89-W-Body-Regal Posted February 15, 2024 Author Report Posted February 15, 2024 (edited) On 2/5/2024 at 2:32 PM, Schurkey said: Low coolant light was lit up on my '92 for a couple of years. Then it went out. I wouldn't guarantee that it's the sender at fault. Could just as easily be the wire harness with bare wire, or a fault in the instrument cluster. I would absolutely verify the harness before I crammed-in another sensor, whether from GM or an aftermarket sensor from a local parts store. Ok, I checked the sensor a week ago and the wiring. The sensor I got was back in July, last year. I replaced it because I was putting a new radiator in and wanted to save time. I also got a new engine installed too so I wanted to replace some sensors to put on the new motor. I needed a new ECM as well because water got into it. The shop installed everything with the new engine. The low coolant light was on. They thought maybe it was the ecm. But the ecm had no codes and wasn’t causing any drivability concerns. So they said it could just be a bad wire like you said. The shop knows I know my car better than anyone inside out because I provided the parts and found the motor myself. I checked the connector and wiring along the sensor. All clean and connector was tight and clean. I thought for the hell of it, the shop gived me my old coolant level sensor back. I put that back on and what do you know the low coolant light went out. So it had to be that nos sensor the dealer sold me. No wonder they charged me so cheap for it. These sensors nos GM are expensive. It was probably a bad sensor they had sitting on the shelf and wanted to get rid of it. I am going to have to drive the Buick and monitor it to make sure the light don’t come back on. I will let you know if it comes back on or not. I am gonna take her for a long drive. Edited February 15, 2024 by 89-W-Body-Regal 92Lumi 1 Quote
cutlassman Posted March 26, 2024 Report Posted March 26, 2024 I had the same problem for the longest time in my ‘92 3.1L. The low coolant light would stay on, even when the level was fine. I finally disconnected the sensor 15 years ago and haven’t worried about it since. I keep an eye on the overflow tank to make sure I’m okay. Quote
89-W-Body-Regal Posted March 30, 2024 Author Report Posted March 30, 2024 (edited) On 3/26/2024 at 2:23 PM, cutlassman said: I had the same problem for the longest time in my ‘92 3.1L. The low coolant light would stay on, even when the level was fine. I finally disconnected the sensor 15 years ago and haven’t worried about it since. I keep an eye on the overflow tank to make sure I’m okay. Yeah I hate when lights are on. The light never came back yet, touch wood. But I am having another problem right now. The coolant tank keeps getting a little low when it's cold out. So I have to keep topping it off. It's not leaking or entering into the oil. When I drive it, it stays full. So I can't understand why i gotta keep topping it off at cold engine when it sits for a couple days. We still are having cool days so when it's cool out it drops a little bit and I have to top it off. I always check my coolant level before I drive it. I am going to have to invest in a coolant pressure tester. Maybe the hose at the tank is bad or not sealing..Both radiator hoses and radiator was replaced even radiator cap. I had all the coolant parts replaced when the engine was replaced. But the shop didn't replace the one hose i told them about I could not find myself. It's an 90 degree long hose that connects to the heater pipe at the firewall and the throttle body pipe. It can either be that hose or the tank hose. It's always low the coolant level at cool so that tells me a hose is not sealing tightly enough but there are not any leaks. I hope the coolant pressure test determines. I hate having to keep topping it off. I know the engine is fine and the coolant stays full when I drive it at hot. The level is only low at when cool outside when it's been sitting a couple of days. Edited March 30, 2024 by 89-W-Body-Regal Quote
Geeraert Posted February 27 Report Posted February 27 Well well... the same story as in my Buick Regal 1988 Ltd 2.8L.... Bad sensor,bad wires,bad dashboard...? The problem is that car inspectors of the Belgian car inspection stations reject the car when the red light low water sensor is on ! And so, no 'green positive inspection certificate ! Not allowed to drive the car,forbidden..! Stupid ! So,my solution : disconnect the electric plug! Good luck Mr Geeraert, Buick Regal 1988,the last one driving in Belgium at 390.000 kms Quote
rcLord510 Posted February 27 Report Posted February 27 (edited) 1 hour ago, Geeraert said: Well well... the same story as in my Buick Regal 1988 Ltd 2.8L.... Bad sensor,bad wires,bad dashboard...? The problem is that car inspectors of the Belgian car inspection stations reject the car when the red light low water sensor is on ! And so, no 'green positive inspection certificate ! Not allowed to drive the car,forbidden..! Stupid ! So,my solution : disconnect the electric plug! Good luck Mr Geeraert, Buick Regal 1988,the last one driving in Belgium at 390.000 kms i believe those are normally open circuit, so it makes sense unplugging it with shut the light off, but I could be wrong after that it should pass no problem. also that’s awesome that there is still a w all the way in Belgium, do you have any pictures? Edited February 27 by rcLord510 Quote
rcLord510 Posted March 1 Report Posted March 1 2 hours ago, Geeraert said: Man those are beautiful Quote
Solution GnatGoSplat Posted March 8 Solution Report Posted March 8 I remember having a lot of trouble with the cheap aftermarket sensors on the 94 convertible. Ended up having to get an OEM one to fix it. Quote
89-W-Body-Regal Posted March 14 Author Report Posted March 14 On 3/7/2025 at 11:42 PM, GnatGoSplat said: I remember having a lot of trouble with the cheap aftermarket sensors on the 94 convertible. Ended up having to get an OEM one to fix it. I think I might have found out what the solution for that. Every time I would do a coolant drain and fill with fresh to bleed system it would always come on saying low coolant. Then when I topped off the radiator it went off. But it would come back on, stay on, go off, stay on , go off it was weird. That fucking light didn’t tell me my coolant was low before. It all started back in 2023 when I was driving and the light came on. It waited until my whole reservoir was empty. And there was no leaks. So I checked my oil and found water and antifreeze was mixing in it. I was told I needed a new engine. So I was able to get one and have it put in. Had the engine for a year now. I’m in the process of replacing a lot of sensor connectors under the hood. I found out that the coolant temp sensor switch for the gauge on the cluster that makes the light function had a broken wire. The connector broke off the wiring harness. So I put a new connector on. I didn’t yet confirm if the light came on because I haven’t driven the car since October before I start doing stuff to it. But that could have been the issue. I did replace the coolant level sensor in the radiator. But it wouldn’t fix the light. So when I put the older one back in the light went off. It’s a weird situation. So will see if the connector fixed it. Quote
bluecalais79 Posted April 24 Report Posted April 24 (edited) The Low Coolant light went on in all 3 of My CS, 2 94's, 1 96. The Coolant was not low. I just disconnected the wire at the sensor. I will change the sensor the next time the radiator is flushed, but until then, problem solved. Edited April 24 by bluecalais79 Quote
89-W-Body-Regal Posted 10 hours ago Author Report Posted 10 hours ago (edited) So nope the low coolant light is still on. I thought repairing the broken wire would help. Not related at all I guess. I would like to find an nos gm oem sensor. Just so expensive and it probably won’t fix the issue. You could have just a 1/4 of coolant below the radiator neck and the light goes on. When I top if off in the radiator it goes off. It seems to only go on when I service the cooling system and have to bleed all the air out of the system. Edited 10 hours ago by 89-W-Body-Regal Quote
GnatGoSplat Posted 1 hour ago Report Posted 1 hour ago Found this, claims to be OEM and has the box to back it up. https://www.ebay.com/itm/256942446998 Although I don't remember my OEM one being that color and having a Sterling Technologies sticker on it. I wonder if you could have a more serious problem though. If you filled and bled it completely, your coolant should never fall 1/4 below the radiator neck. The light coming on when that happens would be normal and expected. When the coolant expands and contracts, it should be pulling from the reservoir and never add air to the system. Air getting into the system when everything is properly bled and sealed implies possibility of head gasket issue. You might want to pressure test or try one of those head gasket leak detectors. Quote
