mybluecutty Posted September 14, 2018 Report Posted September 14, 2018 So I’ve had a lot of mechanicals done to this old bird and it’s taken a good bit of the summer. This week it was brakes, wheels and tires. Next week starts the pace car interior swap. Theres never a dull moment. Imp558, oldmangrimes, primergray and 1 other 4 Quote
kennyb13126 Posted September 15, 2018 Report Posted September 15, 2018 what are the wheels you have on it? I would like something different on mine Quote
mybluecutty Posted September 15, 2018 Author Report Posted September 15, 2018 They are a stock 20 inch Toyota Venza wheel with a 22MM adapter. I sanded them down, shot a coat of epoxy and then black base and clear on them. Quote
mybluecutty Posted September 15, 2018 Author Report Posted September 15, 2018 And a pic with better lighting Quote
mybluecutty Posted November 16, 2018 Author Report Posted November 16, 2018 So I’ve gotten the engine swapped last week and the windshield replaced yesterday. The interior swap will happen next week....finally And a problem was noted on the way home. No heat. Assuming the blend doors are stuck. How do I approach fixing this issue? any help will be appreciated. Quote
kennyb13126 Posted November 21, 2018 Report Posted November 21, 2018 I had an 89 pickup, froze my butt of all the way home one day...stopped by my dads and mentioned it to him, he walked out and slapped the dash with the palm of his hand, the blend door moved and it started blowing hot air. it usually just got stuck every now and then and needed some persuation to move. the trouble was the truck had sat for a while in that one position and it froze ther... Quote
mybluecutty Posted November 27, 2018 Author Report Posted November 27, 2018 (edited) So I’ve been messing with this on my day off. It had to put a new fuse on the interior lamps. I replaced the fuse and the climate control head unit continues to stay lit up even though the ignition is off. So I wonder if the blend door is really a bad Climate Control Head unit? Edited November 27, 2018 by mybluecutty Quote
mybluecutty Posted December 7, 2018 Author Report Posted December 7, 2018 So I got the door panels and seat belt assemblies installed off the pace car. Thankfully everything works, piecing switches and other door parts together. Slow going MemphisMan 1 Quote
mybluecutty Posted December 7, 2018 Author Report Posted December 7, 2018 I’ll save most of it. There are a few switches in different places and I’ll have to figure out the wiring. It just takes time. Quote
mybluecutty Posted December 21, 2018 Author Report Posted December 21, 2018 Pin cups on the pace car. Held in with a c-clip on the bottom oldmangrimes 1 Quote
