Imp558 Posted September 5, 2017 Report Posted September 5, 2017 this was pretty easy but I took a couple of pictures along the way. The majority of the power steering pump failures I've seen have been due to Leaky reservoirs. there are two clips, one on either side all you have to do is release the lock in the Middle with a screwdriver and tap the clip off and the reservoir will fall off in your hand virtually. There is an o-ring in there so make sure you've got an O-ring handy when you put one in. Quote
Dave Kay Posted April 13, 2023 Report Posted April 13, 2023 Have a major power steering leak on my 2000 Grand Prix GT 3.8L and am planning to R&R the power steering pump, lines, etc.,. The only thing I could find so far is this older thread. Since it is in General/Brakes/Suspension/Steering, I would like to know specifically, WHAT VEHICLE, year, make, engine, if possible. Or, if anyone can tell me is my year/model Grand Prix power steering reservoir is a replaceable item? Any help would be appreciated! Quote
94 olds vert Posted April 13, 2023 Report Posted April 13, 2023 I did a quick search and found that the remanufactured power steering pumps can be purchased with or without the reservoir. I didn't see a specific part number listed for the reservoir. On a 2000 Grand prix the power steering reservoir is a replaceable part. I couldn't find a part number. Quote
White93z34 Posted April 13, 2023 Report Posted April 13, 2023 I wanna say thats still relevant information to what you're doing Though I'd say - unless your factory pump is actually whats leaking - keep it and just replace the bad lines Quote
Dave Kay Posted April 13, 2023 Report Posted April 13, 2023 Thanks for that~! Understood, search for replacement reservoir not found. My aim is to buy a new AC/Delco power steering pump w/o reservoir and simply replace O-rings and reuse original reservoir. Quote
Dave Kay Posted April 13, 2023 Report Posted April 13, 2023 1 hour ago, White93z34 said: I wanna say thats still relevant information to what you're doing Though I'd say - unless your factory pump is actually whats leaking - keep it and just replace the bad lines Thanks, see my last post above. At this time, I don't know exactly what/where it is leaking but we looked at it on the lift and it's a lot. My plan includes installing new lines, w/new O-rings. then flush and fill, PLUS, I believe the system bust be bled like brakes. Another bridge to cross. BTW: a nice list of hotrods there~! Thanks again~! Quote
55trucker Posted April 14, 2023 Report Posted April 14, 2023 The pump itself is a relatively common item, that Saginaw TC type 2 design was used on a multitude of fwd cars from that era as well as a few Chrysler/Jeep vehicles. One major operating difference in the pump would be the addition of variable assist steering....your car has it or it does not. The reservoirs were not prone to cracking, without any more information I'd bet that the O-ring seal has failed, unless you've damaged the return line nipple. Quote
IronSled21 Posted Saturday at 12:14 PM Report Posted Saturday at 12:14 PM I’m changing my reservoir on my 04 grand am. The o ring that is between the reservoir and the pump itself. Was bad. I cannot for the life of me figure out the size of the o ring. I’ve tried about 8 different ones and every one leaks . Any help would be much appreciated Quote
Schurkey Posted 5 hours ago Report Posted 5 hours ago On 7/5/2025 at 7:14 AM, IronSled21 said: I’m changing my reservoir on my 04 grand am. The o ring that is between the reservoir and the pump itself. Was bad. I cannot for the life of me figure out the size of the o ring. What is the GM part number for the O-ring? Find out, and cross it to something in the aftermarket if the GM part is discontinued. Quote
