tornado_735 Posted August 12, 2011 Report Share Posted August 12, 2011 In 4 short months these have gotten ugly. I'm thinking trying to blast them with some rust encapsulator/converter type stuff like POR15 or Eastwood frame coating, then welding some thick steel around them and boxing them up. Opinions? Just get aftermarket TAs and call it a day. Quote Link to comment Share on other sites More sharing options...
94 olds vert Posted August 12, 2011 Report Share Posted August 12, 2011 The arms themselves? I would just go buy dormans ones. I've had them for almost 2 years now. I waxed mine before I put them on. Quote Link to comment Share on other sites More sharing options...
white4d96 Posted August 12, 2011 Author Report Share Posted August 12, 2011 ...It's the mounts themselves. Quote Link to comment Share on other sites More sharing options...
Breakdown Posted August 12, 2011 Report Share Posted August 12, 2011 lolwut? I should be able to make it. Really???? Someone from the Chicago area at a Dayton meet??? Unheard of!! Timmy doesn't count because his location is listed as: EARTH. Quote Link to comment Share on other sites More sharing options...
Black92z Posted August 12, 2011 Report Share Posted August 12, 2011 I don't understand why bombing them with primer and leaving it was an acceptable solution. Primers JOB is to absorb anything it can, and in this case moisture. top coat it next time. Quote Link to comment Share on other sites More sharing options...
intern8tion9l Posted August 13, 2011 Report Share Posted August 13, 2011 por 15 the shit out of them. that's what i did, and mine look worse than that Quote Link to comment Share on other sites More sharing options...
Penglii Posted August 13, 2011 Report Share Posted August 13, 2011 por 15 the shit out of them. that's what i did, and mine look worse than that How much cleanup did you do to the corrosion before applying the POR 15 to the nasty trailing arm mounts? Or did you just slather a bunch of the stuff over all of the existing rust? Quote Link to comment Share on other sites More sharing options...
white4d96 Posted August 13, 2011 Author Report Share Posted August 13, 2011 I don't understand why bombing them with primer and leaving it was an acceptable solution. Primers JOB is to absorb anything it can, and in this case moisture. top coat it next time. I didn't leave primer on it when I did them the first time. I wire wheeled them, primed them, and then painted them with one of those "stops rust" enamels (I think that was my mistake in hindsight ) Quote Link to comment Share on other sites More sharing options...
tornado_735 Posted August 13, 2011 Report Share Posted August 13, 2011 I'm sure you're making them out to be worse than they are. You wanna see how far they can go before they fail? Let me look for Robert Saar's trailing arm photo. Quote Link to comment Share on other sites More sharing options...
urbex Posted August 14, 2011 Report Share Posted August 14, 2011 This thread makes me feel good. Mine look a little better than the ones shown here and I thought that mine were getting bad. If you guys all think these look great, that's reassuring for me! Quote Link to comment Share on other sites More sharing options...
AL Posted August 14, 2011 Report Share Posted August 14, 2011 I'm sure you're making them out to be worse than they are. You wanna see how far they can go before they fail? Let me look for Robert Saar's trailing arm photo. Or AMYs TA mounts Quote Link to comment Share on other sites More sharing options...
intern8tion9l Posted August 14, 2011 Report Share Posted August 14, 2011 How much cleanup did you do to the corrosion before applying the POR 15 to the nasty trailing arm mounts? Or did you just slather a bunch of the stuff over all of the existing rust? i gave them a good wire brushing, but that's it Quote Link to comment Share on other sites More sharing options...
tornado_735 Posted August 14, 2011 Report Share Posted August 14, 2011 If your mounts don't look like this: Then you're fine. Courtesy of Mr. Saaaaaaaaaaaaaaaaar. Quote Link to comment Share on other sites More sharing options...
iroc2 Posted October 29, 2011 Report Share Posted October 29, 2011 HELP!! im about to put coilovers on my car right now, and as i was lifting my driver's side by the training arm mount, it was making the sound of rust cracking.. should i stop what im doing and start condsidering every next mile a sucess? or should i be ok for now since the entire weight of the car isnt being held up by it? i NEED input like rignt now, please call me at 630-452-8462 asap please! Quote Link to comment Share on other sites More sharing options...
AL Posted October 29, 2011 Report Share Posted October 29, 2011 Take a picture and post it up and I'll tell you how is from there Quote Link to comment Share on other sites More sharing options...
Go4DaMo Posted November 2, 2011 Report Share Posted November 2, 2011 IT"S OVER, JOHNNY!!! Throw in the towel. Quote Link to comment Share on other sites More sharing options...
BadAzzRegalGS Posted November 2, 2011 Report Share Posted November 2, 2011 Clean them up and use bed liner spray and done... Quote Link to comment Share on other sites More sharing options...
Go4DaMo Posted November 16, 2011 Report Share Posted November 16, 2011 They're really gonna last, already creakin??? Quote Link to comment Share on other sites More sharing options...
white4d96 Posted November 16, 2011 Author Report Share Posted November 16, 2011 Different guy. That being said, I want to get an Eastwood chassis kit and blast the hell out of those before winter hits to try and protect them at least a little bit. Within the next 1-2 winters they will need to be boxed for sure. Quote Link to comment Share on other sites More sharing options...
White93z34 Posted November 16, 2011 Report Share Posted November 16, 2011 I'll add to this. I had the fuel tank out of my z34 last week for a new top seal. the amount of rust under my car was driving me totally insane. wirewheeled the crap out of the whole area on both sides ended up coating the whole area in silver por15, silver because its closer in colour to the factory gray underbody. I need to post up pictures at some point. Quote Link to comment Share on other sites More sharing options...
94 olds vert Posted November 16, 2011 Report Share Posted November 16, 2011 The lack of rust my car has is pretty concerning for how old it and considering it's a MI car. I still found a couple of spots to wire wheel and put Por15 on. Austin, your mounts honestly don't look that bad, I've seen far worse. Unless they have gotten worse since you posted the pictures. Quote Link to comment Share on other sites More sharing options...
AMP Posted November 17, 2011 Report Share Posted November 17, 2011 wow im glad i live more south than you guys that must suck to do every winter. Quote Link to comment Share on other sites More sharing options...
white4d96 Posted November 17, 2011 Author Report Share Posted November 17, 2011 The lack of rust my car has is pretty concerning for how old it and considering it's a MI car. I still found a couple of spots to wire wheel and put Por15 on. Austin, your mounts honestly don't look that bad, I've seen far worse. Unless they have gotten worse since you posted the pictures. They have. They still aren't holey, but the one that dented in is really starting to get that way. I blasted them with some of that Eastwood Internal Frame coating, but of course, an INTERNAL coating isn't meant to survive rock chips and chit. Quote Link to comment Share on other sites More sharing options...
