Mach 5 Posted September 15, 2007 Report Posted September 15, 2007 How do you replace this cable? I broke the other one installing the cross over. Thanks Jarek 92Lumi 1 Quote
93CutlassSupreme Posted September 15, 2007 Report Posted September 15, 2007 i thought the 4T60E didn't have a TV cable Quote
Mach 5 Posted September 15, 2007 Author Report Posted September 15, 2007 I have an 89- its the 440-t4 Jarek 92Lumi 1 Quote
93CutlassSupreme Posted September 15, 2007 Report Posted September 15, 2007 I have an 89- its the 440-t4 Jarek My Sunfire's TV cable just slid into the bracket on the TB, pretty simple Quote
Mach 5 Posted September 15, 2007 Author Report Posted September 15, 2007 The thing is that it hooks inside the transmission somehow. Its the plastic hookup the goes into the trans that broke. Jarek 92Lumi 1 Quote
mfewtrail Posted September 15, 2007 Report Posted September 15, 2007 Jarek, you need to unbolt the cable from the transaxle, then pull the cable up and slide it off of the hook that's inside the trans. I'll edit this post with a picture of transaxle end of a detent cable in just a minute. I have the one off my TGP sitting in my closet right beside the computer. 92Lumi 1 Quote
Bossman429 Posted September 16, 2007 Report Posted September 16, 2007 Matt is correct. When I unhooked mine I found it was much easier to pull far enough out of the trans with the other end (throttle body) disconnected. with yours broken it should already be disconnected. All the end in the trans is is a cable bent 90 degrees and it hooks to a rod with a hole in it inside the trans. 92Lumi 1 Quote
mfewtrail Posted September 16, 2007 Report Posted September 16, 2007 That's how the transaxle end looks, that little eyelet or whatever you wanna call it is what slips over the little hook in the transaxle. Slide off the old cable while holding the transaxle linkage and then slip your new cable eyelet over it, then bolt it down, and adjust the tv cable. Here's the basic adjustment procedure. If you do it like shown(step 4. , it will usually shift a little high(mine is always about ~200rpms high on the initial adjustment, but yours could be different), so you'll have to adjust, test drive, then readjust to get it where you want it. http://tciauto.com/Products/Instructions/instructions/gm_tv_cable_adjust.htm 92Lumi 1 Quote
SleeperRed90TGp Posted September 16, 2007 Report Posted September 16, 2007 Matt, you should be a mod here also. Jud Quote
Bossman429 Posted September 16, 2007 Report Posted September 16, 2007 Whoops I had it backwards. hole is in cable, hook in trans 92Lumi 1 Quote
Mach 5 Posted September 16, 2007 Author Report Posted September 16, 2007 Thanks guys. Do you think that Napa, Pep Boys, or Autozone will have this part or do I have to go through gmpartsdirect.com? I believe the GM Part # is 10163880. I found this doing a little searching. Correct me if Im wrong. I appeciate the help. Jarek 92Lumi 1 Quote
5speedz34 Posted September 17, 2007 Report Posted September 17, 2007 http://www.gmwbody.com/viewtopic.php?t=789&highlight=cable There is a large thread with video at that link. 92Lumi 1 Quote
mfewtrail Posted September 17, 2007 Report Posted September 17, 2007 I don't think parts stores carry detent cables for our vehicles...the last time I needed one, I got it from a junkyard. I happened upon one that was in like-new condition out of a '90 GP that had a service replacement transaxle in it. Quote
Mach 5 Posted September 18, 2007 Author Report Posted September 18, 2007 Well, I ordered the part (GM Parts Direct). That link sure helped me get the full picture. Thanks Jarek 92Lumi 1 Quote
