Rims replacement
PaulGtp
it works now :shrug:
the 10x100/114.3 must be the canadian way of listing the lug patterns. You would need to know the offset to know if they will fit without modification, but the lug pattern should be alright.
114.3 is also classified as 4.5 IIRC. Our 5x115 bolt pattern accepts some 5-114.3/4.5 wheels, but as Jeremy stated you will have to check on the offset. If you know someone who can make you a set of hubcentric rings then the 114.3 bolt pattern should be a sure fit. I actually don't use the rings on my Eagle 185's and haven't had any issues.
