Looking at the AC relay, pins 85 and 86 are the control side. One should have power with the key on, and the other will receive a ground from the PCM when the AC compressor is being commanded on. Pin 30 is the load side power in and pin 87 is the load side power out from the relay. If you have both powers to the relay and the control ground when the AC is being commanded on, but no power out on Pin 87....you have a bad relay. I also just noticed that Test B above is wrong. You can't expect to have voltage on Pin 3 in test A, and be expected to supply voltage to Pin 3 in test B to engage the compressor.
cutlassman reacted to a post in a topic: Remanufactured Engine Recommendations
already have a project cutlass with air suspension and i don’t need two headaches having a good ole shitbox is good sometimes -
Convertible top switch is becoming hard to operate
So, the convertible top switch on my '95 has become somewhat stubborn. The top goes down fine, but to put the top back up, I have to exert an inordinate amount of pressure, pushing the left side inward, as well as slightly upward. I have sprayed the switch liberally with contact cleaner more than once, but to little avail. This problem existed when I bought the car in 2018, but contact cleaner solved the problem for several years, until it reoccurred last year. Anyone know where a new switch can be sourced or have any other ideas of how to address it?
