  2. Human
    Agreed. I always buckled up after closing the door. That said, I really liked the door-mounted belts for their better access to the rear seats. On my '95 convertible, the more traditional floor and ceiling mounted belts and shoulder harness become an obstacle to rear seat access. While I've never ridden back there, I have become entangled in them when climbing in and out to vacuum the rear area. That's the one aspect of the updated interior that I don't like.
  3. Today
  4. What cars can you modify moldings, and which ones to work on a 92 Olaf’s cutlass convertible?
  5. Greetings forum members! New member, so thought I'd take a moment to introduce myself. Last Spring (2025) I acquired a relatively pristine (54k miles) 88 Pontiac GP SE. I hadn't even known they made these with a 5-speed, so I hadn't explicitly been looking, yet lo and behold here we are. I've got it on good authority I'm only the second owner. It started life in central NY but spent the last 10 years parked in a sweltering hot garage in central Florida. It was never ever even registered in FL. So it's got some internal heat damage, which I've been repairing. The door upholstery glue had given up years ago. The stereo was a mess, but I replaced all of the capacitors on the amplifier boards and even plumbed in a bluetooth module to the cassette inputs. I'm not much of an auto mechanic myself, I do cybersecurity for a living, but I don't mind getting my hands dirty on projects like this. On the serious mechanical side, I've had it at a local "rural mechanic" who's did a flush on all of the fluids, changed out the master/slave cylinders, and replaced the brakes. I seem to have dodged the bullet of any serious rust or corrosion, but I know these are prone to rotting out their rear strut towers so I plan on installing a strut tower brace and blast the insides with as much cavity wax as they'll take. Any other "gotchas" tips, tricks, or suggestions for keeping something like this roadworthy? Google's AI guestimates, based on statistical analysis of scrap rates versus production numbers, there may only be 15-25 "roadworthy" versions of this model, trim, and transmission combinations left anywhere I didn't buy this planning on a super rare preservation "duty" yet here I am...any suggestions would be greatly appreciated. Don't worry, despite living in the salt-belt, I don't plan on driving it in winter for that reason...I do hope to drive it during the warmer months though! An 88 GP was my very first car when I turned 16, so I'd always been looking for a decent one, "just for fun". I never planned on ending up with a bigfoot-riding-a-unicorn of rarity...something I'm not all together happy about...yet here we are!
  6. Yesterday
  7. Last week
  8. bluecalais79
    OIL LEAK - 1994 Cutlass LQ1
  9. Jscott
    Sunroof help…
  10. Psych0matt
  11. bluecalais79
  12. Psych0matt
    Sunroof help…
  13. Jscott
    Sunroof help…
  14. Earlier
  15. So I was watching old motorweek episodes on the 1st gen W-Bodies, and grabbed some screen caps comparing the times motorweek got. I realize this isnt bible but its interesting nonetheless! Of note - the quad 4 manual cutlas was the fastest of all to 60, but had a lower trap speed than the TGP and Z34. Clearly the Quad 4/manual was a good choice for this car performance wise - and their commentary on handling was that it was excellent (the most praise of the four) The TGP had the quickest 1/4 mile time, but not trap speed. The video showed very little wheelspin which clearly aided it off the line. The Z34 5-speed had a ton of wheelspin and tire smoke which seems to have limited its 0-60, but its trap speed is by far the highest. Clearly without the wheelspin this would be the “fastest” w-body and demonstrates the best power to weight. The 90 STE turbo was painfully slow compared to the rest, and especially the TGP. Given that its the same powertrain and the coupes and sedans are negligibly different weight-wise, this was either on a very hot day, or they just didnt have a very fast example (maybe a “friday car”)
  16. Rough budget I’d expect $1000 for parts car $500 clutch (spec 2+/3+) $300 flywheel (buy pre cut down and balanced from Fiero Rog in the Fiero Facebook groups) $200 fluids (trans fluid, coolant, oil etc) $200 clutch/flywheel bolts (GM tty bolts are pricey) $100-200 passenger side axle this doesn’t include any fabrication costs and any other “while you’re in there” costs and assumes you are doing all of the labour I’m sure you can do it cheaper but id be budgeting up to $3,000 all said and done
  17. Hopefully you get a notification to see this since it's been so long but I'm thinking about trying this in the future once it's not my daily but do you have any idea how much it was to do this
  18. Black92GS
  19. mikeytcarter
  20. mikeytcarter
  21. Black92GS
    More or less, yes. What matters is where the voltage drop is occurring. If the voltage drop is only at the fuse box itself due to an undersized feed, but the battery is maintaining ~14 volts the entire time, then moving the lights to run directly off the battery will have a positive effect, since they will no longer be subject to the drops affecting the fuse box. However, if the voltage drop is due to the PCM briefly turning off the alternator, or the alternator not yet having caught up to the demand, that drop will be at the battery itself, so it effects everything in the vehicle. Moving the lights directly to the battery wouldn't have an effect there, since they would still be affected by the same drop. In the first video it occurred in conjunction with the AC compressor turning on, which I call normal operation for these cars. My 2000 Regal did that and my parents 97 Lumina always did the same thing. The 2nd video was harder to tell, but it seemingly always happening around the same speed when coasting down makes me think that's when the car is coming out of it's deceleration fuel cut off, and the alternator output is briefly being cut to make the transition back to the IAC smoother. Older vehicles didn't experience this in the same manner, as the alternators weren't controlled by the PCM. Newer vehicles with electronic throttle bodies don't seem to experience this either as the PCM has full control over the throttle itself. I really don't think there is an issue that needs solving. If you want to keep the headlights from showing the effects, you could look at switching to LEDs. The LED chips typically run at less than 12 volts, so they have a voltage regulator to keep things in check. This would prevent them from dimming whenever the vehicle voltage fluctuates slightly. Also, ignore what I was mentioning earlier about the ABS. The ABS kicking in will cause the lights to dim briefly due to the load, but after seeing the driving video, i don't think that's what's happening here.
  22. mikeytcarter
  23. mikeytcarter
  24. Black92GS
  25. primergray
  26. Black92GS
    I don't believe you have an issue that warrants any concern if i'm being honest. I couldn't see the dimming, but I did hear when it took place. What I think is happening there is this: As you're coasting down, the engine cuts fuel and is freewheeling. Once you drop below to a certain speed/RPM, it will switch back to feeding fuel and to the IAC for idle speed control. The PCM is likely cutting the alternator output momentarily at the same time to make the overall transition smoother and to prevent stalling, but this will also result in a drop from charging voltage to battery voltage and then back. Non PCM controlled alternators monitor the voltage and self regulate based on that. PCM controlled alternators have the PCM monitor the voltage and the draw, and can adjust the alternator output as required. It also means they can reduce or cut the output completely in certain states to prevent other issues. If the alternator output is completely cut momentarily, you will immediately drop from charging voltage to battery voltage and then back once the alternator ramps back up. Halogen lighting output and blower speed will change along with this voltage change.
  27. mikeytcarter
    Between the 6 and 7 seconds in this video you can see it if you zoom in. Unfortunately lots of light pollution from the other cars so kind of hard to spot 20251218_182451.mp4
  28. mikeytcarter
  29. Black92GS
