Drain tubes for convertible....
I know this is an old thread but having the same problem. Can anyone help? - Today
Ian reacted to a post in a topic:
Toohfu joined the community - Last week
AFM_Hater69 joined the community -
Getting a pry bar on the studs is next to impossible, given the space you're working with. The service manual for the car calls for a specialty tool literally no one sells. You have to make it yourself. Hope you know how to weld. And grooves to lock it in place? Bolts not work for the engineer? Did narrow wrenches and short sockets not exist in the 90's? The idiocracy of the design choices in the W-Body is astounding! Honda out there making cheap, easy to work on commuters in the 90's while GM was living in their own little city of dreams. Hollow, dim-headed loonies, the lot of them were. - Earlier
55trucker started following 1st Gen W body 14" wheels? and Coilover Spring Rates -
Mrob75 joined the community -
Sway bars just fell off the frame not too long ago and one of the front wheels is pushed up farther than the other one right where he said the subframe cracked.... Rear driver side has a decent hole through the frame too. Was told it was completely unsafe to drive at this point so I only drive it here and there. Will probably drive it until it gives out completely or part out within next couple years.
