  2. I moved the coils on my turbo Monte and I was getting a CEL (1530, I think), but it would run and drive fine. Didn't get it figured out and then it decided it didn't want to stay running. I found the power wire to the coil had a break in the connector I used to extend the wire, so I fixed that and now it cranks, but won't start (no spark). The wires test good and the 7x crank sensor as well. We had put a new ICM on, so I went back to the old one and same thing. From what I've gathered, the only things that it could be is power to the coil, the wires to the crank sensor, the crank sensor or the module/coils. If you unplug the 5-wire connector it should still get base timing and start. Any ideas?
  3. Today
  4. IIRC you can reuse the fabric but when re-applying you start from the center and work your way out because its stretched. I recall an old episode of something car.TV where they redid one. Used razor blades to scrap the old foam off, glued a new sheet on and trimmed it. Then used spray adhesive to put the fabric back on and with a roller went from the center out to the edges. It looked doable but I would want to use a new piece of fabric or even vinyl. You need to remove the front seats and center console to get enough clearance to get the board out then back in. Then you will need an assistant or build a contraption to hold the board in place until all the mounting points are screwed off/on other wise you`ll crease the board if one end drops. I held it up with my head and a large thin hardback book to spread the contact point out, and with knee pads I was able to get the sun visors and rear hooks back in that hold it up.
  5. Last week
  6. Why are you trying to ruin a reasonably-good car?
  7. Don7778
    power windows
  8. I knew what you meant. ChatGPT might be on to something about contact with another material causing it to happen. Maybe it’s reacting with the foam inside?Maybe the foam inside is of a similar composition to the one in the headliner, and the sagging beginning around the same time as the sweating is more than a coincidence? For things like armrests and headliners, Im assuming GM just sources the materials for their manufacture. For all we know, there are numerous suppliers and it’s luck of the draw as to which one ages better. Another variable is where the cars were built. 1st Gen Regals and Luminas were built in Oshawa. Grand Prixs in Kansas, and the Cutlass in Georgia. If there are local suppliers involved for things like upholstery materials, it probably also stands to reason that there could be differences in the chemical makeup of the materials that will lead to them all aging differently from each other. As for the remote control issue, I’ve dealt with that a number of times. It was almost exclusively in remotes that spent a lot of time “in hand”. Also dealt with it in some very well used cordless phone handsets. I always assumed it was sweat and skin oils that managed to migrate their way in. Maybe the humidity was the main factor all along?
  9. It's not melting, exactly. More like sweating or seeping. There's not any noticeable loss of the color material, but it feels like someone's painted honey all over it. I've seen a similar phenomenon happen with old remote controls. The buttons will quit working, and when I take it apart, there's some sticky honey-like substance all over that can be cleaned off with alcohol, but it'll come back. In the case of the buttons, it's silicone oil seeping out. For vinyl, I've read it's plasticizer. ChatGPT assessment - plausible explanation, but sometimes AI is just plain wrong so take it with a grain of salt: Humidity hadn't occurred to me. Not sure that it gets too humid in the car though. It's possible they could have changed the material at some point. It would be a lot easier if they did, as replacing it with the newer version might be a good long-term fix. If I think of it during the daytime, I should go see if the 88's arm rests are doing the same thing or not. Speaking of headliners, that's sagging on my 89 now too. Probably started around the same time as the armrests started feeling sticky. I don't suppose there's any way to salvage the headliner? I'm guess aftermarket stuff isn't going to be a perfect match. Other than the sagging, the fabric itself is perfect. Can't imagine how to get all that foam off the backside cleanly though.
  10. GnatGoSplat
    cutlass wheel fitment
  11. Oh, that's right. I forgot about the guide thing on the earlier cars compared to the later ones. My International is a 91 but due to a deer hit early on in it's life, it has a 88-90 door on it. The seat belt sits differently than the passenger door one. When I get the car repainted, I'm going to add the 91 driver door and fender from MemphisMan's 91 parts car. He was generous enough to give them to me.
  12. No clue. I do know it had an 87 build date, so it was one of the earliest Ws built and that might have played a factor as well. Maybe GM made a material/supplier change across the board due to reports of the previous material failing and some early ones came through with the older material? Perhaps it’s just luck of the draw? The sun visors in my 89 seemed to be made of the same material as the headliner in my 88, and they didn’t show any signs of failure or sagging when it was scrapped in 2015. The 89 had an aftermarket headliner as it had an ASC sunroof, so I couldn’t compare the 2. My 92 uses what seems like the same material as the 88s headliner, and the backing foam still feels nice and springy and doesn’t feel like it’s degraded. As for the front seat belts, they changed the style and likely the manufacturer of the guide when they moved them lower on the door frame and got rid of that stupid tension release system. I find the 91+ front belts to sit more comfortably than the 88-90.
  13. i’d go a little smaller of tire because the overall plan is to put airbags on it when the shop gets a spot open, the goal for me is to have the wheels flush with the body the tires slightly in more than the wheels to have a mean ass fitment when the air bags to air out but
  14. I wonder if it was a styling change, manufacturer or supplier change, or availability, etc? Maybe all of the above.
  15. Different material compositions. I used that example since they were in the same car and in similar spots in the car, the storage conditions could be eliminated as a variable. I’ve seen examples of low mileage vehicles that were stored exclusively in climate controlled environments. Some years and models of GM vehicles will experience headliner sag due to the backing breaking down no matter what. Yes, the climate controlled storage may have slowed it down a bit for some….but probably not as much as we’d like to think. Another observation I’ve made are the front shoulder belt guides. 88-90 are of a different style and material than the 91+. The 91+ style always turned a sort of chalky looking white with age, regardless of storage conditions. The 88-90 style may have faded a bit with tons of UV exposure, but almost always remained nice and black.
  16. That is interesting how the sun visors disintegrated but yet the headliner was ok. My armrests are still soft and pliable, I just had to really clean them due to the years of elbows and forearms constantly touching them. They were pretty dark and black. I used a gentle mixture of Dawn soap and warm water and just gently rubbed them with a lint free cloth until the red started to appear. My headliner and sun visors are perfect in this car thankfully. The STE...not so much. The California desert pretty much baked it's interior. I'm SO THANKFUL that the International has such a nice interior. It's part of the reason why it's a 1 of 1 car. I'm actually restoring the front seats in it right now. The side bolster on the driver's seat is worn out. I'll post pics soon. I have all the hard pieces figured out and collected on the STE. It will be pricey though but I'll do a little at a time. The rear seat headrests and upper top portion of the seat will need to be reupholstered. The front seats are in great condition and just need to be deep cleaned. Same goes for the carpet. Got a new dash pad and found some really nice door panels with perfect door panels. I posted in my thread about all these parts being found. The biggest win was finding a perfect set of door speaker grills and the lenses for the door lamps. Took me years to find those! The original door armrests and the ones I pulled from a junkyard STE...again, not sticky or gooey at all. Pliable and very nice with no cracking or discoloration. I really lucked out there.
  17. The tint definitely would have helped prevent the interior from fading by blocking a lot of the UV rays. But the melting issue is definitely a new one for me when it comes to a 1st gen W. Can’t say I’ve ever seen that happen before….but perhaps the time has come for some of these issues to show up. With the way that car has been treated, I’d expect to have heard other reports of this happening over the years on cars down south years ago if it was common. This is what’s making me think this is more of a chemical reaction and/or a natural breakdown that’s occurring that can’t be stopped with tint or climate controlled storage. Slightly different situation, but my old 88 Regal used different headliner material on the sunvisors than on the headliner itself. The material used on the sunvisors was the same one used on the earlier 80s GMs that was very prone to sagging. By 13 years old, the sunvisors were sagged and the foam material was completely broken down and rotted out. The actual headliner was perfectly fine though, and the foam backing was still holding up well when I scrapped it around 2008.
  18. I really want this car to be as factory correct as I can. That's primarily why I want to go back to a more original look with the clear. Plus, my bud who's a Police Officer keeps hounding me about it, LOL. Definitely not legal for the door glass.
  19. It's very possible, tint does block most UV. That tint looks awesome! I can't get over that you don't like it. I personally hate clear windows in everything. I mean, I really hate it, maybe more than you hate fake DRL headlights. I've seen some people get 35-50% tint and I'm even like, "what's the point?" Getting my Fleetwood tinted is the first thing I'd like to do to it. 35% is legal limit here, but I'm planning to take the risk on 20% like I did on the 94 convertible. I'd meant to take my 89 back to get the front windows done, but never got around to it. Probably should have, if it's indeed UV causing it, but it could very well be a combination of temperature and age as well. The dash vinyl, for some reason, has held up fine. I drove screws into it to un-warp it about 30-years ago, and it's stayed un-warped this whole time. They do make clear tint just to block UV. I was thinking to have that done on the Fleetwood's windshield. It does have a slightly bluish color to it, though. I don't think tint hurts the factory look. Lots of car ads portray them with tinted windows because it looks so much better.
  20. My International sat outside for a good part of it's life. But, the original owner had the windows tinted and even though I don't like it, it saved it's red interior. My armrests aren't gooey yet or breaking down from what I can tell. Maybe the tint helped with this? If I drive it to work, I also put the windshield screen up primarily to protect my repaired non warped dash pad. I'd like to someday have the tint removed and then just have the clear UV protected tint added. I want a factory look but with the added UV protection.
  21. I think a lot of cars have this issue. The Lexus ES generation after mine is notorious for the dashboards (and often the door cards) turning into a sticky, crumbling mess. My generation had issues with the passenger dash air bag shrinking and warping, greatly widening the otherwise tight gap between the bag and the rest of the dash. Here's an example, though this isn't even as bad as they eventually get. I didn't learn about this until I finally starting to find a few in the junkyards where I noticed almost all of the dashes were like above or worse, and then noticed the top gap in mine ever so slightly getting wider. I started using a sunshade as soon as I noticed it, and knock on wood, it hasn't gotten any worse since. Still sucks because the rest of the interior is damn near mint.
  22. Earlier
  23. In all honesty….I don’t believe there is anything you could have done to prevent it. I believe the issue has more to do with the chemical composition of the material and its natural breakdown more than anything else. Likely some combination of the dyes and materials used, cleaning products and skin oils over the years that caused it. If you look at cars that have spent their entire lives in climate controlled storage, you can find some where the headliners have failed in the same manner and in similar time frames as those were exposed to the elements. The foam backing failed mainly due to time, rather than environmental conditions. I experienced something like this a number of years back at work. I was routing and securing cables using a pack of coloured cable ties. The pack was older, but unopened and was stored indoors. They all worked as intended, except for the green ones. Every single one would break apart with the slightest amount of tension applied. The translucent ones and the other colours were all fine. A few years later, we started seeing broken RJ45 jacks….but only the green ones again. Didn’t matter if the jacks were hidden all their lives or exposed to the sun and completely yellowed out….only the green jacks were prone to breaking with very little effort. It had nothing to do with them being green, but something about that particular colour led to them breaking down differently than the others.
  24. rich_e777
    TGP hood vent repair.
  25. jiggity76
  26. rich_e777
    Thank You Needed a win, its been awhile.
  27. wow! that thing was packed full of junk no wonder.
  28. Thanks for posting an update! Now I know why newer cars have a cabin air filter! I wonder how bad mine is.
  29. Thanks for the options but did not need it. since I have a recovery machine with R134a it was not a big deal to open the system and refill it. Yes it was previously converted. after recovering the system I removed the one bolt under the hood holding the lines to the evaporator. Also I removed the clamps for the heater hoses at the firewall. Making sure a pan is under where you remove the heater hoses so not to spill it on the ground. under the dash at the floor I removed both left and right kick panels and gave access to where the bottom of the heater box is. I removed the silver trim around the cluster and radio, unbolted the center stack with that vent, climate control, and pocket. Behind that is another carpeted pocket unbolted that which gave me access to the heater box.. Removed the first panel that direct the floor air flow. There seems to be some pipe that goes into the floor under the carpet no idea where it goes since the back doesn’t have air vents or under the seats lol removing that panel I can see the heater core two or 7 mm. This car seems to be made with 7 mm screw screws.LOL . I was able to pull the heater core to the left and that gave me access to the evaporator. Remove the two screws on the bottom and I was able to pull the evaporator into the car and let me tell you I’ve attached a picture of what it looks like before cleaning it and after cleaning it after reinstalling everything and putting a new O-ring on the AC lines, putting a vacuum on the system and allowing my machine to refill the system with the correct amountthe airflow out of my vents was like a new car and my AC finally blows ice cold. All in all I was only left with 27 mm screws. I have no idea where they’re from but everything is nice and tight and working great. Now I know this isn’t a tutorial with instructions step-by-step but this is just what I had to go through since I couldn’t find any information and didn’t wanna wait for my service manual to come in which yes I did order on eBay. i’ve attached a few pictures before and after. I did do a little bit more cleaning after the clean picture I’ve attached. It looks like a brand new unit now. I hope in the future if somebody has to go through this and doesn’t understand what I’ve typed then can always reach out to me with questions.
