  2. Amanita
    Lowering a W-body?
    I've probably put my Grand Prix through the ringer more in the past decade than anyone else on this forum and, at least for first gen cars, I feel the springs are the weakest link for how they handle. My car has the sportier FE3 suspension and the amount of body roll is still really high. I have a few pictures of it during track days while in a corner and while it doesn't look that bad I can say that you really do feel all the weight being thrown to the outside of the car. Braking is similar, you feel all the weight getting transferred to the front wheels during an aggressive stop and I've had the back end slide out from behind me a few times because of it. I think the best way to improve the handling for these cars is stiffer springs and better tires, but good luck finding a shop that will fabricate a new monoleaf for you. This isn't nearly as much of a problem with second gen Ws since those actually have some aftermarket options, but I do have a '98 Grand Prix and still feel like the springs need to be stiffer on those as well. I will also add that I do think dropping the car by an inch or so will help so long as you have camber bolts or some other way to adjust the angle the wheels are sitting at, the center of gravity in these cars isn't that bad but it could be better.
  3. Today
  4. Last American Indian
    Lowering a W-body?
    First let me say that anyone should do as they wish, obviously, with their own car! That said, I believe it’s important for proper information in making decisions that affect not just the performance of such choices, but safety. Most will pass over this as just so much yada yada, but those that understand engineering, physics, the principles of energy & much more may take a moment to read & think about this. Recently there was a mention in a post about the lowering of the W-body’s! It was stated that such a choice was a bad idea & I concurred, but I would leave it there at that time! I would like to address those reasons here! Reasons many people believe lowering a car's unsprung suspension is a good idea & will help a car handle better often comes from others who make assumptions & never do the math, really don’t understand the entire physics involved or know how to do the real work that is required to know what their actual numbers are & never truly put the car to a real test to prove it out! Yes they may take that car around a corner faster or it may corner flatter at the same speed as before & it feels good, but what if they really had to push it? So the first fact, & you can research this yourself, is a double wishbone suspension & a macpherson strut suspension are worlds apart. The first can be infinitely fine tuned. The latter can’t! The first has many components that can be adjusted to affect roll center. The latter does not. With a double wishbone you can change caster, a lot, you can change camber a lot. You can effectively do a combination of movement of both caster & camber forward & out or in or rearward & out or in whichever you chose. With combinations to create many performance effects & these are just two parameters that affect suspension physics. With many double wishbone suspension you can find lowering spindles! This allows changes to the geometry of the lowered suspension with regards to CG while allowing RC to remain unchanged or altered whichever you chose. For the simplistic explanation, this amounts to the car being lowered, but roll center remains the same,with proper adjustments, as does suspension travel! In a Macpherson strut suspension this does not happen. There is no simple way to change caster! Camber you can, but it has limitations compared to a double wishbone. There are no lowering knuckles for Macpherson suspension for obvious reasons! The bearings are so large there is no room to alter the knuckles. As a result, suspension travel is negatively impacted. Roll center changes negatively, in a bad way automatically & you can’t do much to alter it. Then there is this. How many truly know what their roll center is? How many know how to figure it? Better yet, how many of you can do your own wheel alignment? If all you did was put in lowering springs, & as such the car seems to corner better; then the answer to the above is you don’t know! This means if you were ever to be in a situation of needing to maneuver excessively quick, at a higher speed you might find yourself in serious trouble! In finality, suspensions are very complicated. There are over 100 mathematical calculations involved in setting up just a front suspension! Instant center, roll center, center of gravity, jacking force, anti jacking force, etc… to name just a few! In the end you can make an FWD handle! Not just well, but high end sports car well! But, not by lowering the car!
  5. Yesterday
  6. Last week
  7. carkhz316
    LS4 swap begins
  8. 94 olds vert
    Muffler options
  9. Jscott
    Muffler options
  10. carkhz316
    Thanks for this.
  11. Earlier
  12. Go4DaMo
    Wheel fit
  13. I knew the make/model, not specific years. the bell housing is different. Google's gay robot doesn't know about the TC. It also thinks it was in a 94 Lumina. Like hell it was.
  14. 55trucker
    Wheel fit
  15. Psych0matt
    New to this place. Hello.
  16. rich_e777
    Wheel fit
  17. 94 olds vert
  18. 55trucker
  19. 94 olds vert
  20. Hi, I have a 92 Chevy Lumina Z34 automatic with the V6 DOHC. It's all stock. I am new to fixing cars and got it a year ago. Any tips or suggestions is appreciated. The current thing I'm working on it wiring and brakes.
  21. RPE1992GPSE
    Should I go back to stock?
  22. There's a guy in Denver that we used to use a lot that checked mine out that might be worth talking to: Steve's Transmissions and Gears 303-744-7904
  23. carkhz316
  24. 55trucker
    Wheel fit
  25. rich_e777
    Wheel fit
  26. Psych0matt
    Wheel fit
  27. It shouldn't be much lower than it was, but I definitely should get it aligned again. It's hard to tell since I had them all the way apart. I should have measured the wheel gap and/or fender height from the ground before and after, but I didn't for some reason.
  28. pwmin
    Wheel fit
  29. I'm seeing -.65 on both front wheels as the finished setting by the shop, that's a little more than negative half a degree. You're at just under 1 degree negative on the rears. I personally wouldn't adjust those at all, but those settings were done 2 years ago, you've had the front end apart & the car now sits lower, that will alter those earlier settings to some degree. Lowering the car will induce more negative camber.
  30. I'm at just under - 1. I raised it a little more.
