  1. Yesterday
  2. 55trucker
    Cooling fan questions
  3. Megavolt-380
  4. 55trucker
  5. Megavolt-380
  6. jiggity76
    91 Grand Prix window motors
  7. pwmin
  8. jiggity76
    New to me 93
  9. anyone on here that owns a cutlass with aftermarket wheels could you post a picture under this post of your ride, with wheel fitment specs. thanks to all i’m trying to figure out what type of wheels i want to put on and i was also wondering if a set of 18x8.5 +30 wheels would be too wide for the front or if the offset helps tuck enough
  10. I have the same thing happening on my Lincoln but not other cars. Its slowly turning the steering wheel and parts of the door cards a pinkish, lavender color from the light grey it should be too. I keep a reflector screen in the windshield so most of the interior stays in the shade. So I`m not 100% convinced its just the sun causing it. A similar thing is happening with a firebird where a black tar like substance is building up inside several electrical connectors in the engine bay like the big firewall C100.
  11. You could fill the the trunk up with bags of cement and deflate the back tires.
  12. rich_e777
    New to me 93
  13. jiggity76
  14. jmjp5055
    New to me 93
  15. mdpierce8
  16. 55trucker
  17. White93z34
  18. 55trucker
  19. Last week
  20. White93z34
  21. Megavolt-380
  22. 55trucker
  23. 55trucker
  24. Megavolt-380
    about 12v and below
  25. Megavolt-380
  26. White93z34
  27. 55trucker
