I have zero issues doing this physically, I just have no idea of the internals of this newer one are the same, and I’m not sure I want to bastardize both and end up with nothing haha I was gonna plug the old one in and close it so I could at least drive it but it makes getting to this piece 1000x more difficult lol
X -
