That is correct 55...., It has been a bit confusing trying to figure out just the blocks, just the rubber pads, both? To me bother would lift the rest too high and the rubber pads would wear through eventually. I am thinking the blocks will last for a long time, maybe longer the the car, who knows. It has been an interesting experience and I've learned far more about W bodies that I thought I'd ever learn lol. Still curious about actual parts numbers to build the rear coil overs. Thanks for the feedback - Today
Radio replacement for a 1994 Cutlass Supreme Convertible
Cojack87 joined the community
Jakey joined the community
GnatGoSplat started following 92 (88-94?) sunroof relay and Mono spring delete or suggestions
