Human replied to 89-W-Body-Regal's topic in General
I had this issue with my '95 CS convertible when I first got it in September 2018. I replaced the sensor and that solved the issue. I can't remember whether the part was OEM or aftermarket. I think I ordered it off of eBay, so it may well have been an aftermarket replacement. It was a pain to install without removing the radiator from the car. I had to use a hammer to lever it into place. I lost a fair amount of coolant in the process, so there was obviously plenty in the system. -
All rubber and felt moldings on a cutlass 92-96 bery
Todd replied to Todd's topic in Cutlass Supreme Convertible
Please -
Todd joined the community -
Todd posted a topic in Cutlass Supreme Convertible
What cars can you modify moldings, and which ones to work on a 92 Olaf’s cutlass convertible? -
amiko started following 1988 Pontiac Grand Prix SE w/Getrag 282 5-Speed
Greetings forum members! New member, so thought I'd take a moment to introduce myself. Last Spring (2025) I acquired a relatively pristine (54k miles) 88 Pontiac GP SE. I hadn't even known they made these with a 5-speed, so I hadn't explicitly been looking, yet lo and behold here we are. I've got it on good authority I'm only the second owner. It started life in central NY but spent the last 10 years parked in a sweltering hot garage in central Florida. It was never ever even registered in FL. So it's got some internal heat damage, which I've been repairing. The door upholstery glue had given up years ago. The stereo was a mess, but I replaced all of the capacitors on the amplifier boards and even plumbed in a bluetooth module to the cassette inputs. I'm not much of an auto mechanic myself, I do cybersecurity for a living, but I don't mind getting my hands dirty on projects like this. On the serious mechanical side, I've had it at a local "rural mechanic" who's did a flush on all of the fluids, changed out the master/slave cylinders, and replaced the brakes. I seem to have dodged the bullet of any serious rust or corrosion, but I know these are prone to rotting out their rear strut towers so I plan on installing a strut tower brace and blast the insides with as much cavity wax as they'll take. Any other "gotchas" tips, tricks, or suggestions for keeping something like this roadworthy? Google's AI guestimates, based on statistical analysis of scrap rates versus production numbers, there may only be 15-25 "roadworthy" versions of this model, trim, and transmission combinations left anywhere I didn't buy this planning on a super rare preservation "duty" yet here I am...any suggestions would be greatly appreciated. Don't worry, despite living in the salt-belt, I don't plan on driving it in winter for that reason...I do hope to drive it during the warmer months though! An 88 GP was my very first car when I turned 16, so I'd always been looking for a decent one, "just for fun". I never planned on ending up with a bigfoot-riding-a-unicorn of rarity...something I'm not all together happy about...yet here we are!
amiko changed their profile photo -
amiko joined the community - Last week
SuperBuick started following TOM ( SUPERBUICK) and Bob and Rob's Gen 2 Aluminum Rear Knuckle and Brake Upgrade. How-To with Pics
koleno joined the community -
Sk1pppy joined the community -
OGK joined the community -
Jscott started following Sunroof help…
Rad97 joined the community -
OJD06 joined the community -
Marc Wilson joined the community -
More or less, yes. What matters is where the voltage drop is occurring. If the voltage drop is only at the fuse box itself due to an undersized feed, but the battery is maintaining ~14 volts the entire time, then moving the lights to run directly off the battery will have a positive effect, since they will no longer be subject to the drops affecting the fuse box. However, if the voltage drop is due to the PCM briefly turning off the alternator, or the alternator not yet having caught up to the demand, that drop will be at the battery itself, so it effects everything in the vehicle. Moving the lights directly to the battery wouldn't have an effect there, since they would still be affected by the same drop. In the first video it occurred in conjunction with the AC compressor turning on, which I call normal operation for these cars. My 2000 Regal did that and my parents 97 Lumina always did the same thing. The 2nd video was harder to tell, but it seemingly always happening around the same speed when coasting down makes me think that's when the car is coming out of it's deceleration fuel cut off, and the alternator output is briefly being cut to make the transition back to the IAC smoother. Older vehicles didn't experience this in the same manner, as the alternators weren't controlled by the PCM. Newer vehicles with electronic throttle bodies don't seem to experience this either as the PCM has full control over the throttle itself. I really don't think there is an issue that needs solving. If you want to keep the headlights from showing the effects, you could look at switching to LEDs. The LED chips typically run at less than 12 volts, so they have a voltage regulator to keep things in check. This would prevent them from dimming whenever the vehicle voltage fluctuates slightly. Also, ignore what I was mentioning earlier about the ABS. The ABS kicking in will cause the lights to dim briefly due to the load, but after seeing the driving video, i don't think that's what's happening here. -
Maybe you'll want to look into something like this: https://www.summitracing.com/search/part-type/headlight-conversion-harnesses/product-line/united-pacific-headlight-relay-harness-kits -
