  2. Stiffen them up? or raise the car slightly
  3. Psych0matt
    Coilover Spring Rates
    I'm running (iirc) 450 and 350 and it's pretty dang tight, but not super stiff on normal roads (so it does suck sometimes around here haha). I'm gonna look back and see if I can find if my memory is correct edit: close, 400 and 350
  4. So far, it rides better. I need stiffen them up a little because the tires scrub on bumps sometimes.
  5. Yesterday
  6. 55trucker
    Brake upgrade completed
    The Ford rotor *hat* is shorter, the overall height of the Ford rotor is only 1/4" more than that of the W rotor. The Impala rotors bolt circle is 118mm (4.6"), the W rotor is 115mm & the Ford is 114.5mm (4.5"). The Ford rotors pad surface thickness is near identical to the W rotor thickness 1.040" vs Ford 1.101".
  7. Last week
  8. GnatGoSplat
    Should I go back to stock?
  9. I have for 24 years used the nylon pad/blocks and have had no problem. I bought and installed the rubber pads with the 3-M adhesive after cleaning them while a new rack unit was being installed. They didn't stay in place so I bought the nylon pads which lifted the car back up to a nice stance. I did grease the ends of the leaf spring. I have zero complaints and have had the car for 27 years. I replaced them once and I bought an extra pair and should install them again.
  10. Raffaelli
  11. Black92GS
  12. Raffaelli
    These are crown Vic 12 inch rotors? Curious why you didn’t use later w-body 12 inch front rotors, like an 05 impala? Seemed like it would work also… BTW -nice work! Custom stuff is always so cool.
  13. 55trucker
    The fronts are not adjustable *out-of-the-box*, one has to use a dremel tool to open up (oval) the 3 front shock tower holes inwards to get a negative adjustment. At the rear one needs to (again) oval the thru holes at the bottom of the strut (inwards) to allow the knuckle to be moved *inwards* to get a more desirable negative setting. I'm sure that negative at both ends will change the cars handling characteristics to your liking.
  14. Amanita
    The last time I spun was when I was getting ready to go into a turn going 70+ and the back went out sending me sideways. I think what happened was at least one of the discs got really hot and made the braking force imbalanced since I wasn't attempting to turn at that point. Since then I've switched to a better brake fluid and put EBC Yellowstuff pads on the front of the car which I think are the most performance oriented compound you can get for the first gen Ws at this point, I tried getting rear pads as well but they are just not readily available. Haven't tracked it since doing this, but I'd like to get it back out there within the next year. I didn't know that about the alignment. The next time I'm getting ready to track it I'll take it to an alignment shop and have that done, Thanks for the advice!
  15. 55trucker
    Given what you're doing with the car going bigger can't hurt, when you say you've spun out the car because of the brakes is that because the tail is loose & breaks free in a corner under braking? Being an FWD car the tail is more likely to follow the front where the front goes as the the back end is not driving the car. Something else to consider is the factory camber the cars alignment is set to, it's not slalom considered at all, the fronts are set to a .8 positive camber setting while the rears are at just on the + side of 0. If you were to go to a negative setting on both the front & rear I'm sure you see a far more responsive & more neutral response.
  16. Amanita
    I'm curious how well this does, I know my usecase isn't at all what these cars were designed for but on track the weakest link for these cars are the stock brakes. I have a '96 and even with the larger rotors they get really hot, I'm using pretty aggressive pads and they get toasty really easily, I've spun the car and gone off track because of it. I always just assumed that the next step would be to figure out how to fit larger calipers on the front and rear that can also take better pads.
  17. Well, I completed my front brake upgrade, gone are the 10 1/2" rotors & in their retired place are a pair of 12" rotors. My approach for this was to maintain the original W calipers & just install larger dia rotors in the same manner that GM did when replacing the 10 1/2" rotors with 11 1/4" rotors. The W calipers are more than adequate on their own merits. The 11 1/4" calipers are pushed further out from center by a later design in the caliper bracket adapter. Seeing as I didn't want to purchase & then alter the 95-96 adapters I reconfigured what I had on the car. To do this alteration one has to remove the adapter that is welded to the steering knuckle. One has to cut away the outer section of the *ears* that the caliper bracket is bolted to. I sourced a length of 1/4"x2"x 12" A36 hot rolled mild steel flatbar, this bar is already stronger than the stamping of the adapters & the flatbar is thicker than the adapter by .050 thou. Starting with the drivers side which being done 1st served as the guinea pig for any mistakes I know I would make. I cut off the adapter, gave it a blasting, laid it out on a workbench & proceeded to mock up what the new longer *ears* would look like to get what was needed. Out of the 12" of flatbar I cut 4 *ears* each the same size, from there I laid out on each one the location where I would need to drill the 9/16 hole for the thru bolt. The *ears* have to be shaped into a circular manner on their edge so as to fit into the valley on the backside of the caliper brackets & be able for me to pivot them to get the appropriate angle before tacking them to the adapter. This mod requires that the new *ears* be overlaid onto the backside surface of the adapter. The new rotors *hat* is 1/4" deeper than the original rotor so the need for 1/4" flatbar to move the caliper back inward to get the proper location for the new rotors. Now the adapter has to be fastened back into place on the knuckle behind the hub assembly, install the new rotor onto the hub & lock it into place with a couple of wheel nuts, bolting loosely the *ears* to the cast caliper bracket I can now place the bracket over the rotor to get an approx location where the position will be that is the same as the original caliper was placed. I now install the caliper & the new pads into the bracket & slide the entire assembly over the new rotor, getting an accurate height position for the caliper on the rotor I now need to check that all of the caliper pad is contacting the rotor face. Seeing as the 12" rotor has a larger diameter one needs to make sure that the outer edge of the rotor will clear the inside edge of the stationary bracket but get all of the caliper pad on the rotor surface. I had to remove the brackets & mount them into a bench vise an carefully remove approx .030 tho of surface inside the very upper edge of the upper & very bottom edge of the lower portion to expand the radius to get the needed rotor clearance as it spins inside the stationary bracket. After doing this I can now reinstall the assembly, position the assembled caliper & bracket, position the new *ears* over the cut off ends of the adapter, tighten down the bolts to hold the *ears* where I want them & now tack the upper & lower *ear* into position. I repeated this same procedure for the right side but it went much faster seeing that after completing the left side I now have a template use for the right side. The welding was simple, remove everything from the car, bolt the cast caliper bracket to the adapter to prevent the adapter from warping while welding, mount them into a vise and run the beads, a flat downhand is best for this, the 71M wire puts down a nice wide bead to get maximum coverage for strength in a single pass. This welding procedure requires a minimum of a 200 amp mig, the wire I used was a deep penetration fabrication flux core wire for argon/c02 for heavy fab work such as construction/ship building. A 70S is not recommended. After getting everything assembled back together the last thin to cover is the new rotors hub opening, the W hubs are 70mm dia, the new rotors are 71 mm opening, this means that a 1mm shim is required to slide into the center of the rotor to properly center it over the hub. This was relatively easy, I pick up some 1mm stainless sheet steel & cut two shims 1/4" wide & to length & slipped them into the center of the rotor around the hub stub, then slide the rotor onto the hub. Worked perfect. It's been 2 weeks now since completion, after bedding in the new pads I have done some mild to moderate brake stops, working up to a few panic stops. The difference is instantly noticeable. The car just hauls down to a stop in a much quicker, shorter amount of time. Now since a few years ago when I did the booster upgrade the pedal feel at that time was instantly changed. Going from a hard, less than desirable *no assist* feel to a one can literally stop the car by using ones hand on the brake pedal, the booster supplies so much assist the pedal is like a feather to press. The pads because of their shape do not cover the entire rotor contact face, approx 70% of the rotor surface is made use of & that's the outer portion of the rotor. I have to believe that the smaller 11 1/4" rotors see this as well, not having had any in my hands to compare the contact area with the 10 1/2" rotors I'm pretty sure that THOSE rotors may have a larger dia hat area that reduces the contact area to something similar to the 10 1/2" rotors, these Ford Crown Vic rotors have a *hat* area that is the same as the 10 1/2" rotor hat. All in all...well worth my time & effort & what did it cost me? ...the price of a pair of new rotors & pads & a length of flatbar.
  18. Earlier
  19. rich_e777
  20. 55trucker
  21. rich_e777
  22. As I posted if you want to do your own repairs you'll need a service manual to guide you, the vehicle is an '08, you should be using a proper scanner (not a reader) such as a Snap-On/Matco/OTC to recalibrate the throttle pedal, without that you may not be successful. You CAN try the below......but #4 is where you may fail 1 Turn the ignition to ON (do not start) and wait 3 seconds. 2 Turn the ignition OFF and wait 10 seconds. 3 Turn the ignition back to ON (do not start) and wait 3 seconds. 4 Depress the accelerator pedal all the way to the floor and release it 5 times within 5 seconds. 5 Wait 7 seconds then depress the accelerator pedal and hold it for approximately 20 seconds until the check engine light stops flashing and stays on solid. 6 Release the accelerator pedal and start the engine. Let it idle in park for about 3 minutes.
  23. So... do you know how to know how to recalibrate the accelerator pedal position sensor or not? I'm not buying the manual you mentioned because as soon as I get this thing fixed, they're selling it. And I need to get it done asap. I was looking for an answer to the question asked.
  24. 55trucker
  25. rich_e777
  26. My good man, honestly, you need this...... https://www.ebay.com/itm/236716370404?fits=Year%3A2008|Model%3AGrand+Prix&_trkparms=itmf%3D1%26aid%3D1110018%26rkt%3D12%26mech%3D1%26algv%3DCompVIDesktopATF2V6ReplaceKnnV4WithVectorDbNsOptHotPlRecallWithSiblingFilterCpcRecallsWithCiiQueryEmbedding%26pmt%3D1%26amclksrc%3DITM%26sd%3D167707521148%26sid%3DAQALAAAAEFEOJKTB8w2%2FUvCv%2B9BmnHc%3D%26itm%3D236716370404%26noa%3D0%26plcampt%3D0%3A161936924014%26algo%3DHOMESPLICE.COMPLISTINGS%26brand%3DChevrolet%26asc%3D20201210111451%26ao%3D1%26rk%3D2%26pid%3D101196%26b%3D1%26mehot%3Dnone%26lsid%3D100%26meid%3D031cf1d323cc45f48d590ca2cbbfb577%26pg%3D2332490&_trksid=p2332490.c101196.m2219&itmprp=cksum%3A236716370404031cf1d323cc45f48d590ca2cbbfb577|enc%3AAQALAAABYMJqCZOVY9EoLokt2QswX93oJfuGbORZEZhlCAjlXRRCUbpM9OMIdCmRfkOVQ1PhspDZGTlVp%2BsQFBtO93nb2QX5mVs4lL83nkIbUjqkMa8029EY4XfdhoaLjzTWK5DJUavttt5PoiOIedyWzJY%2FVuksmX506GdUxBoPT1LIWqjfWGejsfPdVITxAKzulOfMQQzvMopxvh020LIFxF%2F1RiyhTFtoeUf0kcPSfyaJp%2BqEsvlJmUmp6P%2B6ZXUDEhrqhuDWjXNRu9Vx3c77Hy1gWwqXTnGUWstmFy1WB81FxnZek%2BvwaLQ4bOU2dwUbV7kufOFF8gwiTc0VeOn%2B4MWaPd1p0%2BUGgIVKXXQHpuXpQgf0Cv%2Btjj2%2B3HQ49QVOK0A3yudeI2kPk%2BCNl8MQHkPLGnFgRvy9lzN5DGtFRlREpsF1GFQ%2Fv6N1%2FfSSN%2F4YIadnCydMbJTrQtw57KcYUXLBA4Q%3D|ampid%3APL_CLK|clp%3A2332490&itmmeta=01KQX3SJVJNPZ9BRW6D2YJV73Z if one wants to be able to diagnose & service their vehicles themselves it is invaluable. It's money well spent.
  27. My grandkids '08 went into limp mode (reduced power) and I've been throwing parts at it to try to fix it. I installed a brake pedal position sensor and had it calibrated, but it's still showing reduced power, so I installed a new accelerator pedal. But after I did, the car's idle was crappy. It sounded weak and was revving up and down (not bad, but noticable), so I figured I had gotten a defective new pedal and removed it and put the old one back on and the idling problem disappeared. While checking out videos on some other GP subjects, I came across one for resetting accelerator pedals by turning the key to accessory, slowly pushing the pedal to the floor and holding it for 10-15 seconds and letting it up slowly. But the guy said at the end of the video that each vehicle has it's own sequence for resetting, so I need to know if anyone can tell me the correct procedure for doing this on our 2008 Grand Prix 3.8. I want to try putting it in again and see if it will work correctly by resetting it, which I didn't do last time. Thanks for any ideas or comments. Lee
  28. Late update- I talked to my transmission guy and when I told him the linkage on the top of the transmission was moving with the shifter through the gears, he just said Something broke on the inside. So I'm having AAA haul it down to his shop. He was kind of surprised when i told him it wouldn't roll in neutral, but he said explained how that can happen, but I can't remember what it was. Anyway, the kids are going to have a long wait since he's a busy guy. He's good, so that's to be expected. He told me it could be less, but expect the cost to be 18-1900 dollars. My daughter asked if it was even worth paying that to have it fixed, and i told her if we didn't, she'd have a 3500# boat anchor. It would either be a parts car or scrap, so get it fixed and the kids will have a car with a rebuilt transmission or at least she could sell it that way. Anyway, tomorrow or the next day I'll have it hauled to by buddy Steve at Farmington Transmission.
  29. No movement, no whining or strange noises. Maybe solenoids? Or transmission control unit. Whatever it is, it's now over my skill level, so I'm going to have to take it to a shop. They need the car bad and I need to get them back in it.
