  2. I need several electrical connectors replaced on my 2.8. Can anyone tell me if they can help me out? I don’t think any of the connectors are going to work with my harness from a 3.1 because I have a vacuum egr valve. The 3.1 mostly has the electronic egr valve and I seen the connectors are completely the opposite. What about the other sensors? Can I crimp these connectors from the harness that has the electronic egr valve and crimp them onto my harness that has the vacuum egr? list of connectors that need to be replaced due to a critter chewing them. The bastard even chewed all of my weather packs smh. MAP SENSOR- GREEN WEATHERPACK - VAPOR CANISTER PURGE VALVE SOLENOID- TAN WEATHERPACK - EGR VALVE- GREY WEATHERPACK 2.8 only vacuum - CRANKSHAFT POSITION SENSOR- BLUE WEATHERPACK - THROTTLE POSITION SENSOR- BLUE WEATHERPACK - COOLANT ENGINE TEMP SENSOR- BLUE WEATHERPACK - IDLE AIR CONTROL VALVE- BLUE WEATHERPACK - OIL PRESSURE SENDER SWITCH- NEAR THE OIL FILTER- GREEN WEATHERPACK - AC COMPRESSOR CLUTCH COIL CONNECTOR- CONNECTOR IS ON THE SIDE OF THE CLUTCH PULLEY- BLUE WEATHERPACK - AIR INTAKE TEMP SENSOR- on the air filter box- BLUE WEATHERPACK
  3. Today
  4. 94 olds vert
    92 (88-94?) sunroof relay
  5. 55trucker
  6. Yesterday
  7. Schurkey
  8. Last week
  9. Psych0matt
  10. Psych0matt
  11. Psych0matt
  12. Psych0matt
  13. There was a time when the rubber pads and SPECIAL glue were available in the aftermarket--Dorman 31066. Maybe it's still available--somewhere. https://www.amazon.com/Dorman-31066-Leaf-Spring-Insulator/dp/B000COCRB4 The way I remember it, the glue was a real pain in the azz, couldn't get frozen, had a short shelf-life, etc. Depending on who you talk to, the rubber pads are--or are not--used with the hard, nylon blocks sold by Moog and others.
  14. Nuts, nope. Thanks anyway rich_e777 for the input but I just checked and the Cadillac Allante convertible top motor is a totally different construction, so it won’t work. that’s too bad too because it seems to be cheaper.
  15. I wish I had the knowledge, they really didnt intend on these Verts lasting all that long it seems. IIRC and I`m stretching hard into the memory banks, I recall something about the pump from a Cadillac Allente. Another thought, what about a local company that rebuilds tools and industrial equipment? Perhaps its entirely possible to replace internal parts the same way its done with alternators and rack and pinions.
  16. !!! A quick update for those that may still stumble on my question above. Checked the electrical all the way to the motor/pump and it’s fine. Checked the fluid level and it’s fine. Tested both relays and they are working great. I was given a suggestion to tap on the casing of the motor/pump, and that worked. The top goes up and down again. Its lift strength seems pretty wimpy so I still need to look into a possible new motor. Here’s my updated questions… Can I replace just the motor side of the motor/pump (I saw a listing on line for about $50)? If not, the only replacements that I’m seeing will cost about $350. Are there other options for replacement motor/pumps that might be a bit cheaper? Options for specifically 91-95 Cutlass replacements seem to be very limited. About motors/pumps off of a Camaro?
  17. crazyd
  18. Apparently It’s called a spring plate. If I’m seeing things correctly, it seems like it’s used to attach to lower part of a spring compressor.
  19. I dont understand what the purpose of those wings hanging off the struts are. Curious why they are/were there.
  20. I have a 93 Cutlass convertible and after getting it out of winter storage a couple weeks ago I finally had an opportunity to put the top down and take it for a drive. Though I hear a slight clicking sound that seems to be coming from back by the pump, the top does not go down or up, and the pump doesn’t seem to engage at all. It seems that very little information is available. I looked for a fuse that would control the power to the pump and was not able to find one that looks like it is dedicated for that use. A relay is a possible problem, but I am having troubles finding that. Reading what I could find on this website, it sounds like a relay or relays could be back by the pump. I can try testing that, but because the top doesn’t move in either direction, I’m not sure if that will be the problem. If you have any ideas, please let me know. Thanks.
  21. Earlier
  22. Describe the *noise* you are hearing.......you say that this was heard when the original spring was still in place? Does the *replacement* spring still have the rubber pads glued to the ends of the leaf?
  23. The spring is installed and functional, the car a bit higher in the rear but I expected that. What I didn't expect is for the noise to return after about a day. I am wonder if it is the point where the spring contacts the plastic isolator and or where the the isolator sit in the bracket. Any ideas are appreciated.
  24. 55trucker
  25. 55trucker
  26. crazyd
  27. crazyd
  28. Schurkey
  29. 55trucker
