  1. Yesterday
  2. Vegeta
  3. Psych0matt
  4. Looking for info for parts..... anyone here available with info?
  5. Last week
  6. I think I used a 2x4 between the studs to twist it.
  7. Raffaelli
    Fuel Pump Replacement
  8. ctaco
  9. GnatGoSplat
  10. ctaco
  11. ctaco
  12. GnatGoSplat
  13. Raffaelli
  14. ctaco
  15. ctaco
  16. 55trucker
  17. Raffaelli
  18. ctaco
  19. GnatGoSplat
  20. Earlier
  21. GnatGoSplat
    Drain tubes for convertible....
    Probably need to reseal your back window (windshield urethane is what I used). Mine had no drain and used to collect water, but I resealed my back window and it never collected water ever again.
  22. Topless1994
    I know this is an old thread but having the same problem. Can anyone help?
  23. bluecalais79
    A/C Repair - LQ-1
  24. Black92GS
  25. 32 Clicks of Rebound Force Adjustment (I'm assuming single)
  26. The softer the spring one uses the stiffer the dampening that's needed to keep ones ride from *floating*. Are these Rev9 shocks single or double acting?
  27. Well, crap, I'm an idiot Spring Rate(FRONT): 8 kg/mm (448 lbs/inch) (8k) (Spring Rate(REAR): 5 kg/mm (280 lbs/inch) (5k) https://www.ebay.com/itm/363295804829 BC (from ZZP): 5k Front, 6k Rear ZZP: 6.6kg front spring rate, 6.6kg rear spring rate Looks like I'm going to switch the fronts out for probably 6k if I can find them in 200mmx62mm (7.87" x 2.44") and try that. I believe the other ones use 10" springs, but I'll have to measure the other car this weekend.
  28. Hmmmmmm.......... the Rev9 supplier doesn't disclose the coil spring rates to the customer? is it safe to assume you're using the 97-04 Buick Regal coils? https://coiloverkits.com/collections/rev9-coilovers/products/buick-regal-coilovers-1997-2004-rev9-hyper-street-ii-32-way-adjustable
