already have a project cutlass with air suspension and i don’t need two headaches having a good ole shitbox is good sometimes -
Convertible top switch is becoming hard to operate
Hey contact Don Ouvry he’s a member of 5th generation olds cutlass group and Oldsmobile Club of America Don just picked up another 95 convertible among his collection of 5th generation cutlasses so he has parts
