  2. Bake82
  3. 55trucker
  4. Yesterday
  5. Black92GS
  6. so this is my first post here on this forum and i don't quite know what to get out of it, as you saw I'm attempting to get all pieces together to get a 5.3L LS4 swapped into my 95 Oldsmobile Cutlass Supreme SL. Being a obd 1 car i don't know if its only the ecm/ecu that runs the tranny or if there's a bcm ( body control module) that goes with it, that being said this car was given to me as a gift from my grandfather who recently passed, so if you guys are tryna convince me to start with something else forget it, ive seen the motor go into the car already and the guy who posted it here was even brave enough to get a 4t80 inside along with it. my main question is what ecu and standalone kit would be best used for this setup as i only see all other ecu's being compatible with the other LS engines instead of this one
  7. Last week
  8. GnatGoSplat
  9. Yep, I've probably removed the bezel a hundred times across 3 Cutlass Supremes and it's never broken. It's hard plastic and seems brittle, but it's actually quite durable.
  10. Good point, it may. I'll keep an eye on it. My feeling is at this point it will outlast that car. It will be interesting to see and I'll check in after a while to let the members know. Thanks for the feedback
  11. Applying grease to an area subject to road-splash and dust entry may be counterproductive.
  12. The glas leaf would be in an *ok* situation if the ends were curled up slightly to allow the end of the leaf to lay flat in the knuckle opening *without* the rubber isolators, then the friction between the end of the leaf & the nylon pads would be lessened.
  13. That is correct 55...., It has been a bit confusing trying to figure out just the blocks, just the rubber pads, both? To me bother would lift the rest too high and the rubber pads would wear through eventually. I am thinking the blocks will last for a long time, maybe longer the the car, who knows. It has been an interesting experience and I've learned far more about W bodies that I thought I'd ever learn lol. Still curious about actual parts numbers to build the rear coil overs. Thanks for the feedback
  14. Ok, I take it by that wording the original rubber pads are not on the ends of the glas leaf, the glas leaf is riding directly on the nylon blocks. This is not an ideal arrangement, but other than getting a pair of the rubber pads in place there's little one can do, the ends of the glas leaf do not tilt upwards at all to allow the weight to spread out evenly at the very end of the leaf where the contact to the pad is, the very end of the leaf will dig into the nylon pad.
  15. https://en.wikipedia.org/wiki/Oldsmobile_Cutlass_Supreme According to the link, the last convertible was built on Feb 15th, 1995. I would be wary of this seller. Could possibly be a scam if they're not educated in these cars and is that headstrong about proving how wrong you are. Make sure they're pics, (if some are shown), are consistent and nothing looks odd. So many times I've dealt with sellers listing so many wrong pieces of information. It's not only about W's either, many makes and models being listed with wrong info over the years.
  16. That's your only option. Once those screws are out, you have to pull that bezel towards you as it's held on with tension clips. The clips are metal and won't break. I've never had a problem with the bezel breaking either. It will sound like it's going to break...creaking and moaning, but it will come. Also, I just disconnect the connector for the headlamps switch, I don't remove it from the bezel. With the bezel out, you'll see two 7 mm screws I think they are that holds the radio to the main dash. They will be at the bottom of the radio. The radio will slide out and give you some room to disconnect the connectors from the back of it. Disregard the dash pad being off. It's not necessary to remove the pad when just removing the radio.
  17. Hello all, Hoping someone would be able to help me resolve a disagreement I'm currently having with an individual who is wanting to sell a cutlass convertible. They have it listed as a '96 model year, and even before I started researching the subject, I was pretty certain the last year for the conv. was '95. I did some research, and politely suggested that he had miss-typed the year in his add. His response was similar to the effect of, "I can send you an image of the title, and you should Google it, and do your research." So I dug a little deeper, and didn't find anything anywhere supporting the fact that the convertibles were produced into the 1996 model year. Before responding to them, does anyone have any supporting documentation or a link to such, to help prove my case? Thanks in advance!
  18. Does anyone know what is involved in removing the radio on this model? The trim is brittle and I don’t want to break anything that can’t be replaced. I removed the trim screws from under the top of the dash but I’m afraid to slide the trim out that goes around the radio and gauges.
  19. The blocks are without the rubber and just help in place by the spring tension. After liberal use of Lucas red and sticky on the blocks the noise has stopped. It has been about a week now so I'm hopeful this issue is solved. Thank you all for the reply and info
  20. Psych0matt
    92 (88-94?) sunroof relay
  21. GnatGoSplat
  22. Psych0matt
  23. GnatGoSplat
  24. Psych0matt
  25. Loctite Hysol 11C glue is actually a really good 2-part epoxy. I use it to repair lots of things. I keep it inside, but the shelf life has been pretty good, lasting over 2-decades. Used it last December and it was still good. That Dorman kit worked pretty well for me, I think I repaired at least 2 W-bodies with it and never had a repeat repair. Shame it's not sold any more. It was supposed to be equivalent to OEM replacement ends and looked identical, so you didn't need the Moog blocks with them.
  26. GnatGoSplat
  27. Psych0matt
  28. Earlier
  29. Psych0matt
