OIL LEAK - 1994 Cutlass LQ1
GnatGoSplat started following GM part number for Eaton supercharger on Series I 3800 v6 and 1992 Cutlass Supreme Coupe Door Speakers
GnatGoSplat replied to Northstarlc3's topic in Powertrain
91-93 88984224 94-95 12480745 Hope that helps. -
FR9. Hope that helps.
There are various designs...plastic or steel.......seeing as you don't intend on getting into this sort of repair again I'd suggest just picking up the plastic set, you should be able to find them at Harbor Freight. The inlet (pressure side) is 3/8 as for a gas can..really up to you..pick up a pair of containers that will hold a total of 15 gals?
