  2. architect
    Draining Gas Tank - 95 Regal
    Got the fuel line disconnected and fuel can ready to go but no go on the fuel pump. Do I have it wrong here? The car has been sitting for 6 weeks so the battery may be weak but radio turns on.
  3. Yesterday
  4. bluecalais79
    OIL LEAK - 1994 Cutlass LQ1
  5. Last week
  6. Amanita
    TOM ( SUPERBUICK)
    Damn, that's a rare one!
  7. SuperBuick
    TOM ( SUPERBUICK)
  8. SuperBuick
    Welcome!
  9. jmjp5055
    1972 cutlass Convertible
  10. GnatGoSplat
  11. Earlier
  12. Raffaelli
  13. bluecalais79
  14. 94 olds vert
  15. bluecalais79
  16. 55trucker
    Sunroof help again.
  17. Jscott
    Sunroof help again.
  18. bluecalais79
  19. GnatGoSplat
  20. 94 olds vert
    anyways, welcome to the site.
  21. Psych0matt
  22. bluecalais79
  23. RPE1992GPSE
  24. Good day, I have been a W body enthusiast since high school 04. In my student parking lot, we had a 93 Gran prix, 94 olds cutlass supreme, 94 cavalier z24, 95 monte, and my lumina z34. These cars were everywhere! My first car was a 94 lumina z34 (still have it). In 2012 I put a 4.9 PFI in it and it is almost complete. I just need to replace the rear suspension and odds and ends. I have a 99 Monte (needs some work), and I just picked up a decent (needs some work) Cutlass supreme. I am buying a new top for the cutlass on Friday. I want to get black canvass instead of the white (the car has black leather interior). They come in black, grey, white, red. What do you all think would be the best color? Just curious. Very few of these ole buggies still around (at least in my area). I thought I would join the forum to see what you all are up to (I feel very late to the party). I already have seen some super nice examples of these cars (nice job everyone!). Ill post more as spring hits and I can get them out, and work on them more. Also, not adverse to loading them up on the trailer for any meets that might happen. Thank you! Hope you all have a wonderful day!
  25. Bake82
  26. White93z34
  27. GnatGoSplat
  28. bluecalais79
  29. 55trucker
    1972 cutlass convertible
