  2. Yesterday
  3. jmjp5055
    1972 cutlass Convertible
  4. Last week
  5. GnatGoSplat
  6. Raffaelli
    OIL LEAK - 1994 Cutlass LQ1
  7. bluecalais79
  8. 94 olds vert
  9. bluecalais79
  10. 55trucker
    Sunroof help again.
  11. Jscott
    Sunroof help again.
  12. bluecalais79
  13. GnatGoSplat
  14. 94 olds vert
    anyways, welcome to the site.
  15. Psych0matt
  16. bluecalais79
  17. Earlier
  18. RPE1992GPSE
  19. Good day, I have been a W body enthusiast since high school 04. In my student parking lot, we had a 93 Gran prix, 94 olds cutlass supreme, 94 cavalier z24, 95 monte, and my lumina z34. These cars were everywhere! My first car was a 94 lumina z34 (still have it). In 2012 I put a 4.9 PFI in it and it is almost complete. I just need to replace the rear suspension and odds and ends. I have a 99 Monte (needs some work), and I just picked up a decent (needs some work) Cutlass supreme. I am buying a new top for the cutlass on Friday. I want to get black canvass instead of the white (the car has black leather interior). They come in black, grey, white, red. What do you all think would be the best color? Just curious. Very few of these ole buggies still around (at least in my area). I thought I would join the forum to see what you all are up to (I feel very late to the party). I already have seen some super nice examples of these cars (nice job everyone!). Ill post more as spring hits and I can get them out, and work on them more. Also, not adverse to loading them up on the trailer for any meets that might happen. Thank you! Hope you all have a wonderful day!
  20. Bake82
  21. White93z34
  22. GnatGoSplat
  23. bluecalais79
  24. 55trucker
    1972 cutlass convertible
  25. I’m looking for the left driver side rear top rail. It connects to the left rear panel.. Need asap
  26. I’m looking for the left driver side rear top rail. It connects to the left rear panel.. Need asap
  27. GnatGoSplat
  28. GnatGoSplat
  29. RPE1992GPSE
