My 93 STE and 96 Cutlass sedan don't have the big rubber springs...but DO have sway bars. But...my 91 International has BOTH. Is that what you're referring too?
dropping the rear of cutlass
rich_e777 reacted to a post in a topic: New to me 93
jiggity76 reacted to a post in a topic: Cooling fan questions
about 12v and below
goldrush25 joined the community
what if i js took out the rear monoleaf and put some spacers would it work ? i mean the ride will obviously be bad but as long as it will actually drive like that i think i’d be fine with that -
Autopia.sa joined the community
White93z34 replied to 97cutty's topic in Brakes/Suspension/Steering/Wheels/Tires
Not really any of those as I recall. once upon a time someone made lowering leafs, pretty sure unless you find one of those your only option is DIY coil overs, Its been done here but honestly I was never into that so I can't speak to it
