  2. I'm putting together a comprehensive plan to stave off the rot out of the rear strut towers in my '88 GP SE 5-spd. Background Not sure how well known this is, or if this is a whole W-Body issue or something unique to the Gran Prix's, but this is what I've learned in my research. The factory seam sealer used on this generation was petroleum based, standard at the time, but over the years the petro chemicals leach out of the substrate, which creates micro-fractures in the sealer. These micro-fractures, through capillary action, soak up salt water and hold it tight up against body metal, thus accelerating body-rust in the exact locations the OEM seam sealer was meant to protect. Additionally, there's a void-pocket between the inner and outer sides of the strut towers themselves. Over time, condensation collects in those void pockets due to heating-cooling cycles and the resultant moisture has nowhere to go and thus sits in there and rots out the rear strut towers from the top-side down, while the seam sealer defect eats them from the bottom-side up. My Plan (Please Suggest Corrections) Drop the wheels and struts entirely. Power wash the wheel wells Wire wheel/brush the factory seam sealer away entirely Horizontal shelf where strut tower is spot-welded to the frame Vertical seams Circular seam where the strut mounting studs poke through. Spray wheel well side with Corroseal Use a 360 degree spray head to flood strut tower voids with Corroseal Allow 48hrs for Corrosel to fully react Spray Eastwood 2K Epoxy Primer. Apply from the wheel wells up Apply into the strut tower void from the trunk-side, down Wait 24-48hrs for primer to cure Apply 3M 08367 Urethane Seam Sealer to the same places in the strut tower that we'd removed the factory seam sealer from. Inject 3M 08852 Cavity Wax Plus into the strut tower void cavities accessible from the trunk side w/360 degree spray head Install a GM Buick "F-Bar", part 19417890, across the rear strut towers. Bead weld the "cups" to the "bar" for complete rigidity Unload the suspension by raising the rear of the car before installing the strut bar, so that it will be under tension immediately. That's my plan, it's entirely speculative based on a whole lot of research, so please let me know if you tink I'm going down a bad road, or if there's any avenues for improvement. From my personal research, this aside from catastrophic loss, this generation of Grand Prix's were more than likely to be scrapped out from this design flaw than anything else, so staving this off should help preserve my longevity, but please let me know what you think! Sincere Regards, AJM
  3. Today
  4. Psych0matt
    Sunroof help again.
  5. Yesterday
  6. Jscott
    Sunroof help…
  7. Jscott
    Sunroof help again.
  8. Psych0matt
    Sunroof help again.
  9. Hey guys, kind of sad to see this community fade over the years, but hopefully some of you have some thoughts on this. I bit the bullet and put a new engine in my ‘92 CS Convertible, 3.1L. Most of the top parts were transferred over to the new block. Old engine ran fine before, but blew out the LIM and hydrolocked. Runs and idles great now, but above say 30 mph I get sputtering/misfiring on acceleration under load. Any ideas? ICM and coil packs only have a few thousand miles on them. New plugs with engine install. Wires are almost new. Car sat for several months with 3/4 tank, Stabil added, but the fuel is about 10 months old. Swapped TPS. No difference. Vacuum looks good. Older fuel? Fuel filter? Bad injector(s)? MAP? I’m going to take it back to the mechanic if I can’t figure it out myself. IMG_7976.mov
  10. Jscott
    Wiper won’t stop running
  11. Jscott
    Sunroof help again.
  12. Jscott
    Sunroof help again.
  13. Psych0matt
    Sunroof help again.
  14. Last week
  15. Black92GS
    Sunroof help again.
  16. Jscott
    Sunroof help again.
  17. Psych0matt
    Sunroof help…
  18. I had this issue with my '95 CS convertible when I first got it in September 2018. I replaced the sensor and that solved the issue. I can't remember whether the part was OEM or aftermarket. I think I ordered it off of eBay, so it may well have been an aftermarket replacement. It was a pain to install without removing the radiator from the car. I had to use a hammer to lever it into place. I lost a fair amount of coolant in the process, so there was obviously plenty in the system.
  19. Human
  20. Please
  21. What cars can you modify moldings, and which ones to work on a 92 Olaf’s cutlass convertible?
  22. Greetings forum members! New member, so thought I'd take a moment to introduce myself. Last Spring (2025) I acquired a relatively pristine (54k miles) 88 Pontiac GP SE. I hadn't even known they made these with a 5-speed, so I hadn't explicitly been looking, yet lo and behold here we are. I've got it on good authority I'm only the second owner. It started life in central NY but spent the last 10 years parked in a sweltering hot garage in central Florida. It was never ever even registered in FL. So it's got some internal heat damage, which I've been repairing. The door upholstery glue had given up years ago. The stereo was a mess, but I replaced all of the capacitors on the amplifier boards and even plumbed in a bluetooth module to the cassette inputs. I'm not much of an auto mechanic myself, I do cybersecurity for a living, but I don't mind getting my hands dirty on projects like this. On the serious mechanical side, I've had it at a local "rural mechanic" who's did a flush on all of the fluids, changed out the master/slave cylinders, and replaced the brakes. I seem to have dodged the bullet of any serious rust or corrosion, but I know these are prone to rotting out their rear strut towers so I plan on installing a strut tower brace and blast the insides with as much cavity wax as they'll take. Any other "gotchas" tips, tricks, or suggestions for keeping something like this roadworthy? Google's AI guestimates, based on statistical analysis of scrap rates versus production numbers, there may only be 15-25 "roadworthy" versions of this model, trim, and transmission combinations left anywhere I didn't buy this planning on a super rare preservation "duty" yet here I am...any suggestions would be greatly appreciated. Don't worry, despite living in the salt-belt, I don't plan on driving it in winter for that reason...I do hope to drive it during the warmer months though! An 88 GP was my very first car when I turned 16, so I'd always been looking for a decent one, "just for fun". I never planned on ending up with a bigfoot-riding-a-unicorn of rarity...something I'm not all together happy about...yet here we are!
  23. bluecalais79
    OIL LEAK - 1994 Cutlass LQ1
  24. Jscott
    Sunroof help…
  25. Psych0matt
  26. Earlier
  27. bluecalais79
  28. Psych0matt
    Sunroof help…
  29. Jscott
    Sunroof help…
  30. So I was watching old motorweek episodes on the 1st gen W-Bodies, and grabbed some screen caps comparing the times motorweek got. I realize this isnt bible but its interesting nonetheless! Of note - the quad 4 manual cutlas was the fastest of all to 60, but had a lower trap speed than the TGP and Z34. Clearly the Quad 4/manual was a good choice for this car performance wise - and their commentary on handling was that it was excellent (the most praise of the four) The TGP had the quickest 1/4 mile time, but not trap speed. The video showed very little wheelspin which clearly aided it off the line. The Z34 5-speed had a ton of wheelspin and tire smoke which seems to have limited its 0-60, but its trap speed is by far the highest. Clearly without the wheelspin this would be the “fastest” w-body and demonstrates the best power to weight. The 90 STE turbo was painfully slow compared to the rest, and especially the TGP. Given that its the same powertrain and the coupes and sedans are negligibly different weight-wise, this was either on a very hot day, or they just didnt have a very fast example (maybe a “friday car”)
